1978 pinto grill
Date: 07/24/2018 02:18 pm
Date: 04/27/2018 10:28 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 09/10/2018 10:41 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 02/14/2018 01:34 am
  • Online today: 1,166
  • Guests: 1105
  • Total: 1105
88 TC engine swap
Started by 1974pintowagon!, July 14, 2017, 06:01:46 AM
1974pintowagon!
If I do this swap it gonna be turbo. I have a while complete TC that I'm thinking of taking the motor from because I'm getting another motor with lower miles. I'm just wondering if the long block will go in easily and I can figure out other fitments like turbo and what not because I'm sure I'll have to customize the engine bay
72pair
Yes the turbo engine has lower compression (8.0 vs 8.2 maybe). I've had a turbo shortblock as my workhorse for many years (2 different cars, different times each). I doubt you'll notice a performance difference. The pick up bolts are 8mm 12 point. Just swap over the parts from your current engine.
As stated the block will bolt in. The pan change requires the oil pick up to be changed too. If your going to the wrecking yards to get these parts be aware the pick up has star bolts holding it in. One is in a rather difficult position.
Be aware, the T/C are said to be lower compression due to the turbo boost. So, if you are just using the block/head with a normally aspirated set up you will be down on power. I'm not sure if the compression is lost in the pistons or the head. I believe it is in the pistons.
72pair
Absolutely. Just need to swap the oil pump pickup and change the dipstick location for the front sump pan. Make sure it has a pilot bearing for the 4 speed trans. The 88 head has d shaped intake ports so there is a mismatch with your original oval port intake but it will bolt up.
1974pintowagon!
I'm wondering if the long block out of a 88 Tbird TC will bolt right up in place of my stock 2.3 and bolt up to my existing 4speed transmission?
