Date: 04/25/2017 12:17 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 10/01/2020 02:00 pm
Date: 08/30/2018 12:59 am
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
78-80 Windshield
Date: 10/29/2021 03:11 pm
v8 springs
Date: 05/07/2017 04:46 pm
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
  • Online today: 642
Fuel lines
Started by highschool dream, February 24, 2017, 09:42:51 AM
If you have three lines one goes to the fuel pump , one goes to the carbon canister , the last one which is a very small line goes to the fuel pump return line ( if you had a 2.3 ) for anti vapor lock , your carbon canister should be in the drivers side door , if it has not been removed, the line goes to the top of the fuel tank , (vent ) , the other line is the extra line on the fuel gauge sender ,
highschool dream
Thanks wittsend. Looking closer at the gas tank on 80 pinto , I can see that there is 3 lines . one goes to canister on fender leaving two.looking at my 76 v6  pinto, I have one canister , second one goes on intake behind carb, 3rd to gas pump. Would it be or could it be the same for my 302
The small line is the gas tank vent.  Typically it runs to a canister and ultimately vents to the intake system, often through additional hoses and one way valves. You didn't mention the year of your car. On the earlier cars there is a blue canister that bolts near the frame rail. The latter cars I don't know.
highschool dream
Ok so v8 is in and running. Now hooking up gas lines, large one goes to fuel pump and small one goes where?  :o
