78-80 Windshield
Date: 10/29/2021 03:11 pm
convert to stick
Date: 05/19/2018 09:26 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 12/09/2016 08:34 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
80 pinto original
Date: 08/04/2019 10:45 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 07/30/2020 11:45 am
  • Online today: 131
  • Guests: 95
  • Total: 95
Pinto 2.0 head!
Started by Pintoman1971, May 11, 2015, 01:00:36 PM
robertwwithee
Little late but IVEY engines in Portland is the SCCA expert.  Jay is owner.
dianne
Quote from: Pintoman1971 on May 14, 2015, 05:41:52 PM
IN NEED OF 2.0 HEAD! Took mine to the shop and they discovered 3 cracks in the head. Located near Portland Oregon
Saw your message. It's just going to cost you shipping and 10 bucks for my guy to pack it :)
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
Pintoman1971
Once you start talking bigger valves another whole can of worms there. If they do not accurately bore the throats below valve bigger to suit the new valve and the necessary handwork that follows then the new bigger valve often LOWERS flow as it then blocks the flow hole more from the bigger size. You'll definitely be in MUCH higher cost doing that work. The job requires some extra tooling and not nearly any shop will be able to do it, but that doesn't stop them from telling you they can.
The throat size and valve size are picked to be complementary to each other. Bigger valves from other engines often mess up the geometry due to length too, and not just anyone again will have the ability to shorten the valve if needed.
We found back in the days of the family shop that a lot of 'bigger valve heads' we ran across were pretty much junk, including some pretty high dollar shops. Lots of ways to get it wrong and only a few do it right. Buyer beware is the word there.
Just sayin' and no impinging of any name that is mentioned in this thread is intended.
dianne
Quote from: Pintocrazed on May 11, 2015, 06:50:03 PM
Talked to the guy I bought my 2.0 from and he said he put small block chrysler valves in my head
Well, if you need a head just let me know. PM me your address and I'll send it to you. I'll just add like 10 bucks to give to my shipping person for doing it.
He can experiment with this one before you give him yours! Supposedly, this may just drop in and work!
Vehicles:
Pintocrazed
dianne
Quote from: Pintoman1971 on May 11, 2015, 05:25:25 PM
Yeah thats what i was thinking. Sounds like hes trying to take advantage and get some extra cash. Called a couple local shops earlier today after i made this post and both said itll be a couple hundred bucks. Way better than $650 lol
Yeah and they can do it. I have a head here also. Might be expensive to ship though.
Vehicles:
Pintoman1971
Pegasus auto racing supplies is the place.
dianne
Quote from: Pintoman1971 on May 11, 2015, 03:14:24 PM
What are you thinking a rebuilt head should cost for a machine shop to do? Just trying to see if my past machine shop is screwin me or not cause it seemed a bit high for 650 just for new valve work
$650? Is he gold plating it? LOL
Vehicles:
Pintocrazed
I GOT A BIG VALVE HEAD ON MINE BUT I'D HAVE TO SEE IF THE GUY REMEMBERS WHAT SIZE VALVES HE PUT
dianne
Quote from: Pintoman1971 on May 11, 2015, 03:16:52 PM
Also what would be a good valve size? lookin to put some bigger valves into it while im getting the machine work done but just dont know where to start. Stock bottom end but while im getting head work i might as well save some money and throw some bigger valves in.
Scott built some 2.0 engines that are pretty hot. If you search on here you can probably find his build and see what he did or message him.
Vehicles:
Pintoman1971
Pintoman1971
dianne
Quote from: Pintoman1971 on May 11, 2015, 02:27:46 PM
Yeah i have the head! I may be interested if you have a head laying around!
I'll look tonight... But order the parts on Rock Auto and anyone should be able to do the head there.
Vehicles:
Pintoman1971
dianne
Quote from: Pintoman1971 on May 11, 2015, 01:00:36 PM
In need of a new 2.0 head for my 71. If anyone knows of a place in the united states that builds heads for these can you attach the website? Done quite a bit of searching but all i can find is places in the UK. Would like a higher performance head compared to a stock head.
Do you have the head? If so you can send it almost anywhere. I may even have a head at home if you need it. Rock auto has the parts for it also, so if your machine shop can't get the parts you can order them on rock auto and give them to them or have the shave the head and you can put it back together. I have a complete 2.0 also that had the top half rebuilt.
Vehicles:
Pintoman1971
