Date: 10/24/2019 01:45 pm
Date: 10/11/2019 11:13 am
Date: 08/30/2018 12:59 am
1978 bobcat 4speed shifter
Date: 11/02/2023 09:51 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
PINTO TRUNK LATCH & CATCH
Date: 03/23/2018 09:39 pm
Date: 02/16/2019 10:46 am
Date: 09/19/2019 04:43 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
  • Online today: 506
  • Guests: 361
  • Total: 361
Want to buy an engine
Started by pintomagic, June 12, 2015, 02:00:33 PM
dianne
Quote from: slooldracer on June 13, 2015, 06:29:16 PM
I have a 2300 engine, from an 1980 with 39,000 miles . If you are interested contact me
I'll have an extra one soon and a 2.0... If someone needs one let me know...
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
slooldracer
The older I get, the faster I was
Quote from: pinto_one on June 13, 2015, 10:56:09 AM
   With alot of cash ,    Yes it will $$$$$$
Anything can be done with a lot $$$$$$$$$$$$$$$$$$$$$$$$$$... :D
Will it bolt straight in , no it will not ,     With alot of cash ,    Yes it will $$$$$$
I am a little confused.
When you say you want to buy an engine, that includes the block. You don't need to say block also. You cannot buy an engine without the block. You can buy parts for the engine without the block, but not the whole thing.
And dealing with these cars, you really can't buy a new engine. You would be buying a rebuilt one, and the quality of those is all over the place depending on who does the work and what parts they use.
I hope I come across as trying to help you understand, not as an !@#hole. It sounds like you may be pretty new to all this stuff. Which we all were at some point.  ;D
As far as your current engine, like 76hotrodpinto says, unless the inside of the block (cylinder walls, etc) are rusty (which you have to tear the engine apart to see) all you are dealing with is stuff that is easily ( or at least cheaply, mainly your labor and a few dollars in supplies) fixed with some sandpaper/3M pads and paint if everything is working properly.
You may want to replace some things instead of redoing them, depending on cost/ease of removal vs ease of redoing, but for the most part just clean up the rust and repaint. In general, most replacement parts are not as good as the factory originals, so I wouldn't replace stuff that is working well.
If you decide to do this let us know, there are tips and things to avoid we can tell you about. There are definitely some things you do NOT want to get any paint on or in.
Pictures of what you are dealing with would be helpful also.
76hotrodpinto
Try googling it. When you can breath again.. try googling engine cleaner, steam cleaning and painting. If a little rust on the motor is unacceptable, don't look under your car! Most pinto's I've run across have rust, and if that's true of yours too, a "new" motor will cost more than your whole car will be worth, even with a new motor in it.
A rebuilt n/a motor seems to run around $800-$1000 for a short block. A rebuilt head, in the $250 range. Some elbow grease and paint, maybe $100. Those are prices in my area though. If it need's to be rebuilt, it will be nice and clean when it's done anyways. Engine rust is usually just some surface rust, except for exhaust stuff, and doesn't mean squat about the condition of the motor.
Save your money to do more to the car.
pintomagic
Does anyone have a link to where I can buy a 2.3 new engine attached to block would be good  ? 1980 auto
I am in Canada , and want to dump the old  one including block , as parts  and block ,etc are rusty .
