2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 09/15/2019 12:28 pm
Date: 02/08/2018 02:26 pm
Date: 04/20/2017 08:56 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 01/10/2022 03:41 pm
Date: 04/28/2018 04:12 pm
  • Online today: 338
  • Guests: 435
  • Total: 435
Rear Diff for v8 swap and a Thanks for all the info
Started by pgccp, February 12, 2015, 07:02:36 PM
mightyss1
my 79 has the first year 9" from a 1957 ranchero, or such. it does fit without cutting the housing or axles...
Pinto1600
Try and find an older junk yard in your area. Find out if they have any late 50's Fords out back and look for a '57-'59 rear end. It should be a 9" rear end, and it will fit right on the spring pads. But you will have to have new U bolts and redrill the stock shock mounts.
Happiness is..Driving a classic Pinto
Clydesdale80
rangers/explorers from the 90's had a lot of 3.73 geared 8.8s.
Bought a 1978 hatchback to be my first car.
What HP / TQ you plan on ?
Wife had two 07 Rangers. First an auto. Second std. Both had 4:88 gears.
If you go with a 4 speed auto , not a big deal: but will be snappy as heck from take off !  ;D
pgccp
What is everyone using for a rear diff for the v8 swap in their pinto
What is the best newer vehicle to use as a donor to fit under a 1977 Pinto
Will a Ranger 8.8 work? or a Explorer 8.8? Or something else>
Want to say Thanks to everyone that has help me with info and parts.
Thanks Bob
