2 liter blocks and heads
Date: 03/28/2018 09:58 am
Date: 02/08/2018 02:26 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
Date: 04/20/2017 08:56 pm
Date: 08/26/2018 06:23 pm
Date: 02/14/2018 01:34 am
2.8 radiator
Date: 10/25/2019 04:10 pm
Date: 04/14/2023 06:15 am
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 1,166
  • Guests: 112
  • Total: 112
Turbo Pinto?
Started by autonerd, July 20, 2005, 02:15:02 PM
I don't have much time right now, but here is some stuff. Relocate the inner mount hole on the car for the lower control arm; go up 3/4". Install a front anti sway bar if it needs one, not all came with one. The wiring is fairly easy with a basic knowledge of car electronics. Yes a direct bolt if you won't mind cutting the hood and removing the heater box(both can be worked around, see "carbbed turbo" in the help section), and the stock 4spd will hold up, less the shifer if you beat on it. Find a M2 v8 8" rear, or an 8 inch from a 60"s stang will work with very minor mods. Look in the faq section for brake upgrades. Sedans (trunk models) have the lowest weight, due to the folding rear seat and glass in the hatch.
More later,
pintoman
Yes you are nuts,but so am I.The motor and the manual trans. will slide right in.But the battery will have to be moved to clear the turbo.The wiring can be a challenge but can be done.I would use KYB shocks on all four corners.There cheaper than Koni's and just as good.The wagon's do weigh more than the hatchback.Good luck on your 2006 project,thought about doing it myself with some friends.
autonerd
Hi all -- I am putting together a team for the Grassroots Motorsports $2006 challenge (www.grmotorsports.com) -- idea being to buy, build, race (auto-x and drag) and show a car for $2006 or less.
We're putting together our short list and one of the cars we are considering is a Pinto with an engine swap. For autocross racing we prefer light weight and balance; because of the budget we need cheap (used/parts car) parts; and because we are mechanically incompetent we are looking for simplicity. So the idea for a Pinto would be to swap over the powertrain from a turbocharged 2.3 liter car such as a T-Bird Turbo Coupe.
Questions:
1) Are we nuts? (Well, OK, that's an automatic yes for anyone who will race a $2000 car.)
2) Will the powertrain bolt in, and do we have an option of different transmissions? (We prefer manual.)
3) What about wiring and plumbing -- how complex?
4) Suspension parts -- what can we bolt up from other cars (Mustang II, Fox, etc.)?
and
5) Do wagons weigh a lot more than the hatchbacks?
I'm a Honda guy so this is all new to me. Any help/guidance/advice you folks can offer would be GREATLY appreciated. Thanks!
Aaron
