2 liter blocks and heads
Date: 03/28/2018 09:58 am
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
Date: 09/05/2018 06:30 pm
72 pinto
Date: 06/23/2016 12:40 pm
Built 2.0
Date: 10/07/2018 05:27 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 03/14/2020 01:52 pm
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Online today: 447
  • Guests: 389
  • Total: 389
window regulator
Started by junker, September 17, 2014, 03:01:29 AM
jburt
Here are the Ford numbers for 73/up.
Sorry, I don't have the earlier numbers
73/76 - before 8/2/76 --- D1FZ 6223201-B  ----  Dual arm window regulator
The Ford parts book only shows one number so I assume it is the same one for both sides
77/up - From 8/2/76 ---- (RH) D7FZ 6223200-A   ---- (LH) D7FZ 6223201-A
Single arm window regulator
Edit to add: I'm not able to do a numbers search so I can't tell you what you regulator fits.
Hope this helps.
I color outside the lines...
74 Squire Wagon - needs a lot of work.
bbobcat75
from what i can tell about window regulators teh 71-73 are one design 74-early 77 are another and 77-80 are another one - have used the 74-77 in early doors and worked fine!  77-80 use a square runner not a round one like the earlier years!
hope this helps - sorry dont know part numbers!
1975 mercury bobcat 2.8 auto
Hopefully someone knows the details but I believe the regulators were improved in 76 but exactly how I can't say.
junker
 Hi this is the junker and I was wondering if anybody knew if a D7FZ-6223201-A regulator would fit a 1975? Thanks alot Tim.
