Date: 06/18/2018 03:47 pm
Date: 11/14/2019 04:02 am
Date: 03/05/2017 03:27 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 10/26/2020 03:24 pm
parts needed
Date: 02/20/2017 07:58 am
  • Online today: 642
  • Guests: 175
  • Total: 175
fuel gauge???
Started by pinto bismol, August 23, 2014, 02:19:40 PM
It should be a 10-70Ω sender, so a 0-100Ω potentiometer would be suitable. It would also be possible to use a jumper wire, a 47, and a 100Ω resistor to see that it moves up to around the full, 1/2, and empty marks respectively.
As far as testing a gauge out of the car, I can't find a straight answer on whether they need 5V, 6V, or if 5 to 6V is suitable. Either way, really easy to make a power supply with an LM780_ regulator and 9v pigtail from the 'Shack.
A potentiometer(used as a volume control on tv's, radios, etc, back in the analog days) is just a variable resistor that you change the resistance of by moving the shaft. What he is saying is to find the high ohm reading and the low ohm reading, (which I think is 0 and 70ish, but I could be wrong) get a pot that covers that range, connect it to the gauge, and move the shaft to see if the gauge needle movement follows as it should.
Of course I am an electronic tech, so what he said makes perfect sense to me.  ;D
I used to have a big box with all that old school stuff in it, but it went away many years and many moves ago.  :(
Simple, right?  ;D
pinto bismol
can I get that in English please!
LOL
Caution.....explosive personality!
You have to know the OEM low/high resistances and buy a cheap old school volume control or potentiometer that has those values in the spread of the part. Then simply hookup and set potentiometer to low and high values and attach to gauge to make it move.
Is there anyway to test the gauge with it out of the car? I have one from my 74 that I have no idea of it's condition and won't be reusing(I'm going all aftermarket gauges), if I could verify it works you can have it P.B.
I just realised that yours may be different than mine, which is just a plain stock one in the same panel as the idiot lights. But if they are the same the offer still stands.
pinto bismol
tried that this morning and it did nothing...grr
Pintopowers
With the key on did you ground the wire to the tank sender and see if the guage rises?
SR
pinto bismol
My 76's fuel gauge has never worked. Always assumed it was a sending unit problem, probably a float. Well, drained the tank. took apart the old sending unit and the float was gone! Dropped the tank and found it in several pieces on the bottom. Cool! Replaced the float and put everything back together. Well....fuel gauge still does not work. Ohmed everything, and it looks like it should work until it gets up to the instrument cluster. Kind of at a standstill trying to figure out what direction to go. new gauges? where and how much?
thanks!
