1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 04/08/2018 05:47 pm
Date: 04/30/2023 04:31 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 08/20/2017 01:34 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Date: 01/04/2017 04:07 am
  • Online today: 367
  • Guests: 277
  • Total: 277
which adjustable cam gear?
Started by poomwah, April 12, 2014, 04:12:05 PM
poomwah
I was looking at those, the savings is definitely nice. I'm just thinking it might be worth the extra to not have to loosen the belt and remove the cam gear every time I want to make an adjustment.
The ones with several key ways are cheaper and do just as well in the long run.
poomwah
Don't get the ultra light, rather the regular one, it will outlast on a long term street motor. The light one will break, only intended for short uses like racing.
poomwah
I know, that's what confused me about the place selling the different colored fidanzas. they are all slotted with infinite adjustment. But they listed the colors with different degrees. I thought maybe it was the +- range of he particular sprocket.
So, was it a messed up site selling it, or are all the fidanza adjustables the same? I can't even find the site that listed the degree differences for each color.
anyway what would be better , the lightweight one http://www.speedwaymotors.com/Ultra-Light-23L-Ford-Square-Tooth-Adjustable-Cam-Sprocket,32338.html?utm_medium=CSE&utm_source=CSEGoogle&utm_campaign=CSEGOOGLE&CAWELAID=1549156538&CAGPSPN=pla&catargetid=530009170000006315&cadevice=c&gclid=CP6x1J2N3L0CFeZDMgodQmwARQ
or the fidanza  http://autoplicity.com/products/39251-fidanza_986234.aspx
It's not adjustable unless you can pick ANY number you want.................
poomwah
I've seen a couple different ones, I've seen an ultralight one that has a flange machined into the back edge so you don't need the big guide washer.
then of course there's the findenza adjustable. I have seen them on some sights as being different degrees for different colors.  3 degrees for silver, 6 for blue, etc.  I thought they were all the same range, but perhaps not.
What do you guys use and recommend?
