upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 01/18/2017 05:35 pm
Date: 10/11/2019 11:13 am
Date: 04/04/2020 09:38 am
Date: 07/30/2018 04:32 pm
v8 springs
Date: 05/07/2017 04:46 pm
Date: 10/14/2019 08:24 pm
1978 Squire wagon 6 Cly
Date: 03/08/2021 10:44 am
TWM Intake
Date: 08/15/2018 08:20 pm
  • Online today: 584
  • Guests: 414
  • Total: 414
71 front suspension help
Started by L.D, February 18, 2014, 08:34:03 PM
JACKAZZFLATZ
Hey THANKX, EH.  I'll be getting the order in today.
Dont needta "go" fast, just wanna "get" there fast!
L.D
jack pst makes a full kit for the 71 front end upper and lower ball joints and all the bushings not cheap but one stop shopping also fiqured out the upper bushings  only get pushed to the bigger diameter not flush 74 and use bigger bushings you can get urathene for the latter years.
Quote from: jeremysdad on March 12, 2014, 03:10:29 PM
When I rebuilt mine last year, I had to source everything as individual parts. I could not find a complete kit for the 71-72 model years. Rock Auto was my best friend, as well as Ebay. Just buy brand names like Moog and Raybestos, and you'll be fine.
I've gotten great prices on ebay on Moog parts. 4 new lower balljoints NOS under $200 (I have 2 cars to do), new Moog uppers $10 each, upper arm bushings $20 set of 4.  Still need LCA bushings but they're fairly cheap. It just takes time to find what you need.
Quote from: jeremysdad on March 12, 2014, 03:10:29 PMI got my rack and pinion from Autozone. If you search the site, you find my thread about it. :)
My 73 rack needs new inner tie rods & both boots. Advance has a rebuilt rack with warranty under $120 shipped using discount codes. I can't get inners & boots for that so it's a no brainer to buy a rebuilt. Only Autozone has the 71 rack for $136 if that's cheaper than rebuilding yours. I got outer Moog tie rod ends off ebay for my 71 for $15 a pair & I see them cheap all the time.
Quote from: jeremysdad on March 12, 2014, 03:10:29 PMNeat trick a good friend taught me: You can save a few dollars removing the old bushings yourself. Just use an air chisel, they pop right out. :)
Installing upper arm bushings is easy too. A piece of angle iron cut to length to keep the sides from bending while allthread & washers is tightened to pull the bushings in. Lots of WD-40 on the allthread & bushings & you're done in 10 minutes. LCA bushing goes in with allthread, washers & a smaller chunk of angle iron to keep from bending the arm. I don't have a press so this saves money.
 ;D
that's the way i always did it. never had any issues
jeremysdad
Just to clarify, the bushing gets pressed in until the 1.3" step first makes contact with the control arm.  Stated another way: the 1.3" OD section will be visible when done.  Anyway, you can not press the bushing's 1.3" sections into the arm without bending something.
Got curious again and went looking.  A lot of the parts stores advertise parts from these "makers":
Moog has been around a long time but do not offer everything.
http://www.moog-suspension-parts.com/products.asp?cat=9777
Rare Parts is new to me.  They advertise everything including the lower ball joints.  Link does not work as is, need to copy and paste.
http://shop.rareparts.com/smtp/shopdisplaycategories.asp?iyear=1971&imake=0020|FORD&imodel=0479|PINTO&iproduct=0040|SUSPENSION, SPRINGS & COMPONENTS
JACKAZZFLATZ
I'm in the same boat as LD.  So the '74 and up is apparently different ?  Is there a source for replacements, or do i need to make my own ?
They use stepped part so both sides are good and tight when done. The step allows the whole thing to be piloted, if all the same diameter then it gets tight way before the other end can pilot. Pressing that much length always loosens the fit as well. It also guarantees that the bigger washer face is on correct side, otherwise it's easy to press them in backwards by mistake.
L.D
Dick i noticed the measurement you have also indicate around a .050 thousands difference from the small end to the big end there has to be a explanation on this.
L.D
the upper bushing is stepped 1.263 o/d on small to 1.305 on the big end up against the shoulder do the bushings get pressed all the  way in flush agaisnt the flange or stop at the bigger dia 1.305.
Like he says, the bushings are stepped, measure other side too. The actual pressfit will only be like .005", not .050". Try to press 50 thousandths and you will destroy part by splitting it.
LD! The one I have in the shop is 1.438 to 1.449 for the lower and 1.400 to 1.448 for the upper. Both are step'd in their diameter. I though these were for a 71/72 and now I don't know.
LD! It sounds like you've got a 74/80 front end kit. I'll go check one I have and let you know in a few minutes.
bbobcat75
have a complete front end in the 72 pinto runabout I just bought not sure if its the same as what you are looking for!?!
1975 mercury bobcat 2.8 auto
L.D
I purchased a rebuild kit from pst for my 71 the front upper a arm bushings are about a .050 press fit they measured 1.312 and my upper arms I/d is 1.260 is this correct or do I have a problem does any one having any upper arms with the cross shaft for a 71 they would like to sell. Thanks L.D
