Date: 01/20/2018 07:51 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 10/25/2019 03:30 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
Date: 10/25/2019 04:05 pm
Date: 07/20/2018 03:00 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 02/22/2017 01:58 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
  • Online today: 642
  • Guests: 176
  • Total: 176
hedman headers for v8
Started by pintoman2, February 17, 2014, 08:14:56 PM
MII headers don't fit the Pinto at all.
tjm73
Check out the FRPP street rod shortie headers. I think they might work for 302's. Maybe 351W's. Not cheap but well made.
What about 351W Fox swap headers on a 302? Short tubes would tuck close to the block  Long tubes might hang a little low however.
pintoman2
Well the 393w has a dome piston keith craft  brodix heads 210 mill to get the 13.1 a custom bullet solid roller c4 with trans brake 4500 ptc stall 456 gears ran 6.40 in eighth mile on motor 5.90 on spray I would say would ran faster if motor was pushed back also 1.38 60 ft and  dyno 605 at flywheel
dianne
I'm curious, do the Mustang II headers fit it? I found a pair of hookers for mine. They are on ebay once in awhile.
Vehicles:
- 1976 Mustang II mini-stock
- 1978 Mustang King Cobra II
- 1979 Ford Pinto Runabout
- 1986 Chevy K5 Blazer
- 1997 Suzuki Marauder
entropy
Quote from: pintoman2 on February 21, 2014, 07:36:40 PM
Thanks guys I've done all my homework before I got on this website and it was worth a try . Taking the wagon to a header shop next week and after that would like to hit some of these pinto shows Car was basically a strip car have taken out the steep gears and the 13.1 393w to a pump gas 306
What's been done with the 393w?  Um....no particular reason I'm asking....    ;-)
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
pintoman2
I got my Hookers off Ebay for under $200 shipped & they are in excellent condition. Every now & again a set pops up for cheap.
beaner
i have a hooker kit in my car i might sell dont know yet but it is a option :-\
brad :)
Quote from: amc49 on February 19, 2014, 03:06:21 AM
I understand the need for them in certain situations but flat collectors zoop, they do not vacuum from outside pipe to outside pipe very well at all. All 4 need to be in a tight grouping to vacuum each other evenly.
At some point I'll be building a 302w for one of my cars. Will have the Headman headers tested on the dyno & post results.
Quote from: dick1172762 on February 18, 2014, 10:31:19 PM
There's a set of Hooker swap headers on E-bay right now for a Pinto. Asking $556. Look under ford pinto headers. Every body I've talked to say the Hookers are much better. LOL
I don't have a set of Hookers, but if I recall, all the ones they made have the back 2 tubes go through the fire wall.
Like the old B2 headers of mine in this topic: http://www.fordpinto.com/your-pintos/new-car-!/90/
fozzy
Stainless headers mfg would be able to help you out.
http://www.stainlessheaders.com/index.aspx
You basically build your own headers out of abs plastic pipe and knuckles and send it to them. They copy it and weld up a nice set of stainless ones.. Expensive but very pretty!
Guess things have changed over there, there was a time they they would make just about anything.
Quote from: Pinto5.0 on February 17, 2014, 08:55:20 PM
Heddman doesn't make them anymore. A few people have looked into it.
I was in touch with them & no, they will not (ever) make them again.
I have two sets. One set was on a started only engine. One NOS set.
Both will be cleaned up & ceramic coated inside & out.
Sorry, not for sale !
Best & cheapest way to replace them is have another set made, by a good builder.
I think you may still be able to buy the flat collector ?
Well, that's a bummer guess they must have gotten rid of the jig for them.
Have you tried to call Hedman direct?, maybe they would set you up??..
pintoman2
Hello, New guy here and need of your help . I'm need of a set of headers from hedman # 85601 is for the Windsor and cant remember for the 302 block I will take either or mine are not repairable If you know anyone that has these and willing to sell ,it would make my day You can e mail me @ fullerofseven@hotmail.com Thank you
