hood for a 79-80
Date: 11/30/2018 10:55 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 02/14/2019 06:27 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
Date: 10/24/2019 01:45 pm
Date: 09/12/2018 12:33 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 03/18/2020 01:30 am
  • Total Topics: 16,268
  • Online today: 195
  • Guests: 166
  • Total: 166
Starters
Started by yhalkeeiron, March 22, 2014, 01:41:58 PM
yhalkeeiron
And it will start up better than before
Sent from my SPH-L710 using Tapatalk
yhalkeeiron
I used a 1990 ranger starter  make sure its four a 2.3
Could someone give some specifics on what Ranger starter to use?
If I have to replace it anyway,  I would like one that spins more. :-)
thanks,
yhalkeeiron
It works really good
yhalkeeiron
Thanks for all the help I have a brand new Ranger starter  so I'll try that out and I'll be installing t5 transmission soon
72pair
In 30+ years of wrenching on Pintos, I'm pretty sure no partsperson ever asked manual or automatic regarding a starter. My 72 2.0 car has a late 70's 2.3 starter because that's what was on the shelf available. That car was originally a c-4. The same starter went right back in when I swapped in the 4-speed. If it goes, I'm going to the Ranger style. Got one on my 72 2.3 car and yes it spins great.
YES but the Ranger / Mustang starter will turn the motor over like it has all the spark plugs out. Really turns the motor fast.
jeremysdad
My post regarding tooth count was for manual vs auto. As long as you get a starter from an auto 2.3, it *might work. But you can still get the correct 2.0 starters from the parts stores, so that would be my first recommendation.
Here we go......................
http://www.fordpinto.com/general-help/have-starter-questions/
Maybe half way down and please excuse my acting like an idiot in part of that thread.
Look for 'jeremysdad' posts.
Thought someone else chimed in on this like couple of weeks ago, saying the two had different teeth count on bendix. Or I'm going crazy...........................
bbobcat75
have a used starter from a 2.0 if you need one.
take care
1975 mercury bobcat 2.8 auto
72pair
My experience says yes. 2.3 starter is slightly longer and terminal is at the end, but it will bolt up and work.
yhalkeeiron
Will 2.3 starter fit on a 2.0 thanks for all the help
