77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 08/30/2021 03:20 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
Date: 06/19/2018 03:58 pm
  • Online today: 553
  • Guests: 418
  • Total: 418
full left or right steering pump stalls motor
Started by 78_starsky, August 03, 2013, 09:37:56 AM
Biggest thing with rebuilt or new or even old pump is to make sure it does not run dry even for seconds when first filling it up. I have seen them score pump body to make noise forever by simply being slow to get more oil in there. As little as five seconds dry can score the pump if the parts scrape off oil to be dry. I always stand over the reservoir and have someone else crank the motor, that way I lose no time chasing the reservoir level, a good working system can void all oil in it in like ten seconds or less.
If old pump not making noise I wouldn't change it, the hose could've been ready to blow anyway. You NEVER hold power steering on the limit for more than a second, and risking things doing that, the pump ramps up to full output and the bypass (your 'bleed off') bumps open trying to save pump and lines. Sometimes it can't do it..............the systems are not supposed to be abused like that.
Nahh they're easy to re build, glad to hear ya got it fixed. 8)
78_starsky
Hi Fred, thanks for the diagram.  I had already got the new one before i seen your post.  are they hard to rebuild?
Thanks for the info pinto wagon.  All fixed up now and running smooth....  what a pain in the BuTT to change.....   all good to go now,
thanks guys!!!
casey
I just O/H one of these 2 hours ago.   Fred
78_starsky
thanks!    guess i need to replace the pump....    :(
never fails.....  fix one thing to break another......    LOL
cheers
It's an internal pop off valve inside the pump, when you reach full travel the pump keeps building pressure until something gives, thus the reason for a pop off valve to release pressure, I'd say you need another pump.
78_starsky
hey!!!!!   now this happened.  i did have to get the hose replaced as it blew a hole in it!!!!!
can you go further into the bleeding?  i need to know how/where to do this.  never heard of it before can you explain more?
thanks.  or is the pump pooched? and needs to be replaced?
Should be a bleed off in the pump to relieve pressure when you reach maximum travel and you can hear it, without it you can blow the pressure hose.
78_starsky
thanks for that.   i wasn't sure if normal or not, seemed a bit odd to kill the motor that easy.
yes auto no lights on though just running normal.
thanks
jeremysdad
Fairly normal. Fully (to lock) creates a big strain on the pump. It will destroy the pump if you hold it there long enough. Might check to make sure your idle's not set too low. 550 is about where it should idle with lights on, in gear (if auto), and a/c on  (if equipped).
78_starsky
Anyone every had this happen?  When the car is sitting idling and i turn the wheel full left or right the motor will stall out.  The tach shows about 550 rpm then nothing as it dies/bogs the pump out.
normal driving the pump seems ok but might have some sort of drag.  is it possible to hook up the lines to the steering rack butt backwards?
cheers
