Date: 03/13/2021 12:57 pm
Date: 06/30/2018 09:48 am
Date: 02/18/2017 04:44 pm
Date: 06/12/2018 08:18 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 04/04/2020 09:38 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
  • Total Topics: 16,268
  • Online today: 354
  • Guests: 119
  • Total: 119
Welcome
Started by turbopinto72, November 06, 2003, 05:31:54 PM
jpbralley
I think my hood is stuck? I can't figureout howto post this question anywhere else, but I pull the latch, and it comes up, but its like its stuck on another catch or something. (I don't have much experience with cars,my  dads just not home and I can't open it for the life of me)
SeanP
Thank you. Does type F go in manual trans too or just automatics?
Biloxi, MS
1978 brown Pinto Pony trunk
facebook.com/thatbrownpinto
Quote from: SeanP on September 06, 2012, 12:00:21 PM
I'm also in the process of doing fluid changes, including brakes, on my 78 Pinto Pony.  Is there a garage section on fordpinto.com that lists recommended fluids, ie motor oil, trans oil, wheel bearing grease, etc. etc? It's been awhile since I've owned a car with a carb and non-sealed wheel bearings. I don't even have a grease gun for the ball joints.
Welcome!
I don't know if anyone has listed the fluid types for the car but here is what I know by what I have looked up & used.
Motor oil.. 10w30 is recommended by Ford. Trans oil is Type f. I've used regular wheel bearing grease with no problems for years. Can't recall what the rear gear takes but I think it is 75w90. Gas is easy.. regular 87 octane. Dot 3 brake fluid for the brakes, regular antifreeze for the coolant. The universal coolant sold in the stores these days will work just fine. If it has power steering it just takes regular power steering fluid unless I am mistaken.
SeanP
Biloxi, MS
youngboy
I am new to the Pinto and I can't find the place to pour transmission fluid into the car, could you tell me?
scoth69
 :text_yb_please:
what is the silver box on the fender well car wont start i was told this safety box is why
78jr racer
bates 77, are you running dirt or asphalt?
if running in dirt throw away your sway bar you are preloading your chassis.which has a negative affect on handling. you might also play with the lead in your rear axle.trailing the right rear tire from the left rear tire will loosen your car. leading the the right rear ahead ofthe left rear will tighten your car. without knowing car weight  spring weights etc. it is hard to determine exactley what it will take to get lined out. if racing on pavement i haven't a clue on setup i've never raced asphalt before.if you will contact speedway motors in lincoln, nebraska they have a very knowlegable staff. their address is www.speedwaymotors.com phone is 402-323-3200
hope this helps
merle walter
billnall
HI BPANMAN,
Check out links tab an this site and try VFN fiberglass.
Ford Parts Man
bpanman
Hey Everyone,  I'm new here.  I was wondering where can you get aftermarket fenders?  what are some good sites to find parts?  thanks
bpanman
Handy
Here's a picture of my '80 Bobcat.  It looks better in this picture than up close . . . not a lot of rust on it but its in pretty rough shape compared to my '76 Pinto.  Luckily, I found a junkyard close by that even has a '79 Bobcat with enough parts left over to pick off it.    If anyone else has been looking for an odd part off a 79-80 Pinto/Bobcat let me know and I'll pull it before it gets crushed.  This junkyard allows buyers to pull parts but they don't ship out and they're definitely not hooked into the internet.   They gave me a centercap for my rallye wheel for FREE ( I only had 3 out of 4 of the rallye style wheels before hitting the yard . . . there's one wheel still left now.)
1980 Bobcat
1976 Pinto
Handy
Just thought I'd try posting a picture of #2.   Removing the driveshaft was a snap.  Thanks for all the tips.  But rather than wire the shaft to the car, I just removed it entirely and mated a spare slip yoke to the transmission output shaft.  A bungee cord kept it tied to the rear mount.  It was an easy tow even with my 4-cylinder van ('97 Honda Odyssey).
This is a great site.  Keep up the good work!!
1980 Bobcat
1976 Pinto
Handy
Will do.  Thanks again!
1980 Bobcat
1976 Pinto
losin sux
Look for the topic "driveshaft disconnect" in another section of the board that I posted.  You will find one I did after the suggestions.  It is not hard to do and not long at all.  Beats foaming up the transmission fluid.  HOpe it goes well.
Steve
77 HB 2.3 C3 3.40
yes pull the driveshaft if its an automatic and your going to pull it with the rear wheels on the ground. If the car is not running, you'll burn the pump out of the tranny.
Handy
Hi,
Thanks for the advice on the 5-speed.  Sorry for delay in replys but I'm still not quite used to the forum discussion thing.
Welp, I just bought Pinto #2 off ebay.  After failing to find trim parts for the 1980 Bobcat I'm switching to a '76 Pinto that looks a little more intact.  But I have a few questions:
  1.  I'll be towing the Pinto home ( about 230 miles ) using a U-Haul dolly with
       my van.  The roads are fairly straight with only an occassional hill (almost all
       freeway driving ).  Since its an automatic, I had planned to pull the drive
       shaft off to prevent damage to the transmission, rather than just putting it
       in neutral.   Is that being too cautious (waste of energy and is it even
       necessary)?  Any suggestions on towing would be helpful. ???
  2.  Are there any postings regarding upgrading the standard 2 barrel carb setup
       to EFI ( what's needed to make it work with older Pintos).  The turbo
       conversion looks a  bit too complex for me to handle this winter but that's
       a long-term goal/project I'd like to tackle  ;)
Kind regards,
Handy
1980 Bobcat
1976 Pinto
Keebler-kahnn
Handy
Thanks for the info!
1980 Bobcat
1976 Pinto
SVOwagon
I put a 2.3 turbo motor with the 5 speed in my 80 Pinto.
 Yes a mustang or Thunderbird turbo trans will fit, but with some work. If I was you this is what I would do. Get a trans from a Mustang with the bellhousing. You may not need to use the bell housing but if your Cat one doesn't work, you know that you have one on hand that will. I did have to cut my drive shaft and the hole in the floor was trimmed a little. The crossmember works but I had to make an adapter to get the mount to line up.
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
Handy
Hi,
Thanks for the great column.  I'm a newbie to the Pinto scene . . . just started working on cars again after many years away from mechanics.
Anyway, I bought a 1980 Bobcat off the classifieds here and drove it home this weekend.   What a blast!  The drive train, electrical, brakes, steering and suspension all seem to be working fine to me so far.  Although my Bobcat has a 2.3L and 4 speed, with a 8" rear end,  I'm considering replacing the transmission with a 5 speed at some point.
I'm wondering if a 5-speed tranny off a Mustang or T-Bird with a 2.3L  is a bolt-on replacement or would it require modifying the drive shaft or drive train?
Any suggestions would be appreciated.
Thanks
1980 Bobcat
1976 Pinto
samgcpo
Fantastic!  I've been looking for that same wheel info for 2-years.  Thanks!
~Sam ;D
Keebler-kahnn
just checked out the Crower site....Not too bad pricing either! Ive placed my order and will be going to Esslinger's site in a bit. Thanks!
Keebler-kahnn
That makes sence. Thanks for the info...ill be getting my header in next week from Canada so this will give me time to find a cam with that grind.  :)
Later,
Keeb~
Well, I looked up your Crane cam and I see that the duration is 226/234 @ .50 and the lift is 420. ( did't see the 460/480 ) . But any way, thats not a bad cam. I think the cam I like better is the Crower cam, grind #
24273. Is 228/238 dur @ .50 with a 476/493 lift and 110 lobe center. Im sure you could get this cam from summit if you asked. I would STRONGLY recomend using a cam pully. I like the Esslinger unit. This will allow you to take full advantage of your cam and ( dial your car in) alot better. I would start it with " 0" streight up and probably end up with it some where in the 6 to 8 deg advanced setting for that bottom end punch you need.
Keebler-kahnn
TurboPinto72...I have a question fer ya...
As far as the cams go...
My application is street/ strip, daily driver, with my current gear ratio and 4 speed, I run 3000 rpm @ 63mph.
I want a faster take-off, (able to light up the tires from a roll of about 5-10mph), and of course a higher top end.
On my '77 2.3, I want to leave the bottom end stock, stock bore (for now), upgrade the intake, 500 Holley, and Headers.
What Hydraulic cam would you recommend? And what lift/duration would you recommend? I am looking at a cam from CRANE. Description from Summit Racing as follows:
_____________________
CRN-190071  Camshaft, Hydraulic Follower, Advertised Duration 278/286, Lift .460/.480, Ford, OHC 4 Cylinder
Would you recommed this cam, or do you have a better cam that I should go with? I am looking at the price and the ease of the overall build. I have decide NOT to go with the turbo at this time, (rapair of the two turbos I have is out of my pocket and budget).
Thanks,
Keeb~
 Well, to answer your question. You  ( could ) use them on a N/A engine as is BUT the compression ratio may be the least of your worries. Lets say that your engine is 9:1 compression or even 9.5:1. If you keep the boost down you can run any turbo, however the stock cast pistons will probably FAIL. Besides, those drawthru systems  ( the factory 79-81 systems)are not the most efficent things around. What you are discribing with the oil that blows is a oil seal failure. Yes , they can be repaired BUT, you still need to pipe the exhaust around to the intake side and then figure out how to exit the exhaust around the stearing. Not to fun.
Keebler-kahnn
I also have just one more question....I have two, draw through turbo intakes complete. 1 from a 1981 Capri RS Turbo and 1 from a 1982 Mustang Cobra. 1 spools up at idle and blows liquid oil, the second spools fine but blows a freight train of smoke.
If i can get these repaired, will i have to change the compression ratio of the stock non-turbo 2.3? or will it handle the extra compression?
Thanks for the link.
keeb~
 If you go to  Turboford.org   and do a search for that there will be a whole bunch of info. There are several people on this site who have done the swap, ( including myself) and will be more than happy to answer questions.
Keebler-kahnn
Im considering a turbo swap in my 1977 cursin Wagon. Ho whard is it to remove the computer from the Donor T-Bird and install it into the pinto? Are there any sites detailing the swap, step by step?
Thanks,
Keeb~
I bought my carpet kit from JCWitney. It worked well , however it was not molded so it took some extra time to install. If the kit you are looking at is a " molded" kit it will save time. If you want to buy a "used" carpet make sure you ask the seller for additional pictures of all the area's that can get real bad like the drivers feet area etc. The factory units will be pretty funky and who knows what they will look ( smell) like when the get pulled up ( read, a 44 oz. coke spilled 4 years ago and is still rotting away the underlayment). As far as a min bid, go $.50 over and see what happens.
