Date: 04/08/2018 05:47 pm
Date: 03/06/2019 06:40 pm
Date: 08/30/2021 03:20 pm
1973 Pangra
Date: 01/06/2015 02:19 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Date: 09/19/2019 04:43 pm
  • Online today: 148
  • Guests: 126
  • Total: 126
Sounds like a problem...
Started by From_Jonah, March 04, 2013, 09:49:13 PM
From_Jonah
@tbucketjack It doesn't really run but it doesn't go right it. It just chokes out til it goes off. Sometimes it takes a few seconds. Sometimes it's only a couple.
74pintoguy: That's about how much I'm burning. Maybe a little more.
74pintoguy
If the engine makes the noise under load, you may have piston-slap.  The first Pinto I had years ago developed that and the only thing that fixed it was a new engine.  I was using about a quart of oil every 200 miles.
tbucketjack
Sounds like timing, and bad gas. Does it run on when you turn the key off?
From_Jonah
Hey guys! I've not been on in a while but I'm still around. Busy busy haha. Anyways, the Pinto has developed a noise in the motor. It doesn't do it at idle but when I'm accelerating it sounds like someone is shaking rocks in a tin can in my motor. It's pretty darn loud too. I'm also burning quite a lot of oil and when I cut the motor off it acts like it's choking out.
So yeah, I think I  have some sort of problem.
Thanks in advance!
