  • Online today: 1,435
  • Guests: 1393
  • Total: 1393
Power brake booster
Started by 75Wagon 2.8, February 03, 2013, 12:44:12 AM
75Wagon 2.8
Cutelitlputtputt,
Where are you located? Was the car a manual or auto? Do you know what the condition of the master cylinder is? D.R. Ball stated that there may be a difference between the brake pedal mount from non power to power. Do you have photos of the pedal mount?
cutelitlputtputt
Hello '75!
This is a picture of a power brake booster (with pedal) out of a '75.  $80 plus ship
if you want the master cylinder too, then it will be $90 plus ship
http://farm9.staticflickr.com/8499/8449491194_e837167489_z.jpg
Let me know if you are interested!
Anything to keep her runnin'!
Just as a note, I believe the Mustang II and Pinto Pedals are slightly different in length.  The rest of the power brake parts should swap between the two cars.  So if you are planning to go manual trans, then you will need to find a 4spd power brake, brake pedal for your conversion.
I know you need a 2.8 bellhousing from a 4-speed Mustang II to go to stick but I don't think it's drilled for the T-5 trans.
I think that there is a difference between the brake pedal mount for the power booster versus the non power booster. If you want to save some time and money try to get a conversion system to add power brakes to your car. It would be an all in one set up instead of trying to put something together piece by piece. Granted the rebuilt parts are available  but without the brake pedal mount it's hard to do...See if  Fred, etc have any of the parts. I would count on having the booster being old and needing to be replaced.
75Wagon 2.8
Tigger,
The car came with a 2.8 and c4 but I am researching a motor/tranny swap. Would like a manual t-5 but not sure on motor yet. Will all Mustang II fit?
I know of no other vehicle that will interchange.  Oh and it is a bolt in thing provided that you have all the parts needed.  What transmission do you have?
75Wagon 2.8
Is there any other doner vehicles that might work? The mustang II is gating harder to find these days.
Mustang ii parts should interchange.
75Wagon 2.8
Hi all,
I am looking to change from a manual brake to power on a 75 wagon. Are there other vehicles that a booster can be pulled from and what modifications they would need to fit?
