looking for parts
Date: 06/19/2020 02:32 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Bumpers
Date: 07/06/2018 04:47 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 09/01/2017 11:58 am
Date: 03/05/2017 03:27 pm
Date: 02/18/2017 04:41 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 10/24/2019 01:45 pm
  • Online today: 642
  • Guests: 512
  • Total: 512
Wiring question
Started by PintoMaverick, January 01, 2013, 12:02:21 PM
PintoMaverick
Thanks so much for the help Jerry! That clarifies things quite a bit. I'll let you guys know how it goes. Hopefully I can get it ready to fire by next week.
1974 Pinto trunk model, 2000, 4 speed. 1971 Maverick Grabber, 4.6 DOHC 98 Cobra engine, 5speed, Mustang II front suspension, 4 link rear.
A better scan in the pdf format has been emailed.  Have fun with the turbo.
PintoMaverick
Theres nothing left of the factory Pinto harness besides pigtails. The whole care has been rewired. The under dash harness was so chopped up I ripped everything out and rewired with an EZ wire kit. So the wiring is pretty straight up now, no seatbelt circuits in this one.
Travis
PintoMaverick
The LA3 came in the 88 Turbocoupe with a manual transmission.  Below are scans of the 87TC EVTM (similar to the 88TC) showing that circuit.  The 74 Pinto with all the seat belt interlocks is more complicated than the 87TC for this circuit.  Had to reduce scan resolution to get under the 100kb limit here.  If you need a better resolution, pm me your email address and I will email you better scans.
PintoMaverick
Here are a couple better pinouts/diagrams
PintoMaverick
Quote from: oldkayaker on January 02, 2013, 06:22:34 AM
Looking at the 74 wiring diagrams, the red with light blue stripe might be the small control wire going to the starter solenoid.  If this is the case, it functionally begins at the ignition switch, going to the "starter interlock override reset switch", and on to the solenoid.  Note the wire color changes to a white with pink dots for a bit between the ignition switch and the reset switch.
That alternator looks the same as the one I removed from a 87 Turbocoupe except for the connector wires.  My 87TC factory wiring did not match the factory wiring diagram, so I am not sure what is correct here.
Well after doing some further searching I believe you are correct. I had to do a Google search for Ford TFI images, which led me to several different pinouts, all showing pretty much what you stated. I will post them in case anyone might run into the same issue. When I get home today I will try and sort this out if I have enough daylight left.
PintoMaverick
See thats the problem. I have diagrams that show this wire but none show where to it leads just says "to starting and charging system". I have no idea what this harness came out of. I bought it seperately from the engine with an LA3 ECU. What you mentioned about the starter solenoid makes sense so maybe I will look into that a little more until someone has an answer.
PintoMaverick
Well thanks for your help anyway, I appreciate it. Maybe someone else on here will know. Its annoying that this one little wire is holding me up.
I can only tell you red with blue tracer is FLD. I don't know that alt..    Fred   :)
PintoMaverick
We are talking about a Pinto...just one with a 2.3 Turbo engine lol, sorry for the confusion.  ;) . Removing the black tubing wont help because I had to extend those wires because someone cut them off way too short, so they are not factory color. The wire in question comes from the TFI ignition module on the distributor and its the only one coming off of there that I dont know where to hook up. The others are for the spout connector and the coil.
Oh I thought I was working with a Pinto. I may be able to tell you if you remove black cap.  Fred   :)
PintoMaverick
Fred your alternator is different than mine. Here's a pic of mine
Blue arrows point to fld see markings on alt.  Fred   :)
PintoMaverick
Ok I understand you have the higher amp alt the blade connector that is closest to pulley is your fld connecter I will get U pictures.  Fred   :)
PintoMaverick
Thanks Fred. Now where is the FLD on the alternator for a 1988 2.3? Can I tie into the same terminal as the BRN/WHT wire states in the diagram is also for the starting and charging systems? My alternator doesnt have a clear marking for the FLD like the older side terminal alternators do, it has the 2 plug in connectors.
That goes to FLD on alternator .    Fred   :)
PintoMaverick
Hopefully this year I will be able to finish my turbo Pinto after a long break, doing house renovations, work, school, etc. I'm finishing up the wiring for the engine and the rest of the car. I rewired the entire car with an EZ wire kit. All has been rather straight forward and going nicely. Although I have one wire in the factory engine harness I cannot figure out exactly where it goes, and the harness was cut at the pigtail for the alternator. The wire is a Red with Light Blue stripe. From what I can tell from the diagrams I have, this is for the starting and charging system, but it doesn't state in any of them exactly where it leads. I'm assuming on the alternator but I'm not sure on which terminal. I have the rest of the alternator connections figured out but this wire is causing me some problems. Does anyone know where it goes? I really don't want to hook this up the wrong way and fry something. This is one of the last connections before I have everything ready to try and fire this thing up in the next few weeks. Any help would be appreciated.
