Date: 04/12/2017 06:57 pm
Date: 12/04/2018 07:40 pm
1977 Cruiser
Date: 06/29/2019 06:28 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 06/19/2018 03:58 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 10/31/2018 12:04 pm
Date: 03/21/2017 07:47 pm
  • Online today: 288
  • Guests: 236
  • Total: 236
Rear shock
Started by John Turner, January 06, 2012, 07:46:38 PM
Glad you got it done, and right!
Always glad to help and thanks for the update. I always try to let people who I asked for help what happend later....I do not like having an unfinished cliffhanger..
RSM
Good to know you got er done there John. Half assed is not the way to fix anything in my books either. I've worked on so many cars that were repaired like that it makes you wonder what those people were thinking...lol
John Turner
Thanks everyone for the advice.  I removed everything, chased the threads and successfully reinstalled the bolts.  Feels good to have it done right.  (I hate knowing something is halfas--d)  Thanks again.
Remove the bad bolts, run a tap and replace. A bad shock mount is not worth a car wreck.
I agree. Better to be safe than sorry. You wouldn't want one of those shocks to come off while driving.
RSM
I thought they had nuts on the backside too. You probably should remove one of the bolts and figure out what thread it is and get a tap and clean up the threads and install new bolts. Those plates need to be good and tight against the subframe.
They are self taping? I though there was a square nut welded to the inside of the rear sub frame that the bolt threaded into.
Either way, I would make sure it's right and replace the bolts with something better, just to reassure it won't come apart on your later on down the road, literally.
johnbigman2011
Quote from: John Turner on January 06, 2012, 07:46:38 PM
72 Pinto Wagon.  I put in new shocks yesterday. Rear shocks are attached on top to a "plate" that has 3 self tapping bolts in it holding it to the body.  Very rusty, short story is 2 bolts cross threaded.  Tight but not fully seated.  One seated well and tight.  My question;  Does it matter - will it be ok as is?  Or do I need to back em out, get new self tapping bolts, and retighten?) and if I do, should I drill out the holes and install self tapping bolts?  (Bummed)  jt
John, I think I would put them in to insure no movement.
John Turner
