Date: 04/20/2017 10:10 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Mirror
Date: 04/15/2020 01:42 pm
Date: 01/28/2019 05:15 pm
Date: 05/03/2024 05:37 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Date: 12/10/2016 04:11 pm
  • Online today: 367
  • Users: 1
  • Guests: 144
  • Total: 145
  • rob289c
1971 Pinto Engine and Header Questions...
Started by unmarkedcarr, October 10, 2011, 07:53:54 PM
unmarkedcarr
And, since I'm here and trying to figure this whole thing out, does anyone on this forum manufacture the custom motor mounts?
1971 Ford Pinto Runabout
unmarkedcarr
Ok, so I figured out that it's a 2000 cc in my 1971 Pinto.  Thanks for the clarification from you all.  So, as far as a new set of headers, I'm out of luck?  No other Pinto header will fit it?
Mark
fast64ranchero
No one in the states make a direct fit header for the 2000cc engine, you might find a used one, or you can get one that works
with a new passenger side motor mount.
72 old V-8 parts Pinto
73 pinto, the nice one...
RSM
Only 2 choices in 71 like 72Wagon said. Easy to tell the 2 apart. The 1600 has the carb on the passenger side of the engine and the 2000 is on the drivers side.
72Wagon
In 1971 Ford offered only two engines 1600cc and 2000cc.
1972 Wagon
unmarkedcarr
Hey, I have a 1971 Pinto with a 2300 stock engine in need of headers.  Summit Racing says they have headers for a 2300 cc 1974 model.  My question is this - are there any differences in the engines from 1971 and 1974 and would the header from the  1974 work on my 1971?
I'm pretty much mechanically UN-inclined so any help you can give would be appreciated.
Mark  unmarkedcarr@gmail.com
