Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 11/04/2018 02:34 am
73 Runabout
Date: 11/20/2017 03:19 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 11/23/2017 05:44 pm
Date: 11/11/2019 04:49 pm
  • Online today: 2,415
  • Guests: 2236
  • Total: 2236
Head light surrounds.
Started by tinkerman73, March 26, 2011, 07:10:04 AM
tinkerman73
Jody Michielsen
vonkysmeed
73 Pinto Runabout
351w from 74 galaxie
Heads from 69 Mercury Cougar
6 point cage
tinkerman73
Jody Michielsen
vonkysmeed
Those are called Eye lids and they look cool, but completely render the highbeams useless.  If you take them off you should be fine.  They are most likely pressure fit under the light ring and should be an easy operation.  If not, you should be able to use any ring of any 7 inch light.
73 Pinto Runabout
6 point cage
tinkerman73
I have a pair of headlight surrounds the include a cover that actually covers about half of the head light. I am going to assume here that these are aftermarket pieces. I have noticed that it is better running low beams then high beams. The high beams do not luminate as far as the low beams in my opinion. Has anyone else had these and had these issues? I think I would almost like to trade these off for normal ones? any points or tips? Thanks.
Jody Michielsen
