  • Online today: 2,909
  • Guests: 2670
  • Total: 2670
Transmission Mount
Started by Bwayrshires, April 12, 2005, 08:18:58 PM
any performance place will be able to hook you up with one, i don't have the part number. They only make one mount for all C4's
Bwayrshires
Thank's, do you happen to know the part number.
Thasnk's again, Brian.
my mount is an Energy Suspension for a C4 , works great!
Bwayrshires
I don't have the stock mount, it had a 4 speed that I took out. I have heard that you can't use a solid trans mount with solid engine mounts, need to have some flex in the driveline, so I'm told. I work at a Ford dealer and the stock mount looked a little flimsy by the picture and I don't think it's available. Just curious what you guy's are using.
Thank's, Brian.
Can you modify the stock mount and replace the rubber with poly or a chunk of aluminum???
Bwayrshires
I have a 74 wagon drag car with a 302 that I am re-installing the c-4 trans. I have solid engine mounts, what are you guy's using for trans mounts. I found a Lakewood mount in Jegs, but it is $45. Thank's,Brian.
