  • Online today: 2,773
  • Guests: 100
  • Total: 100
2.3 cyl. heads
Started by RapidRichy, December 02, 2010, 10:42:59 AM
RapidRichy
oldkayaker thanks for all the good info. I need to pick up on a cyl. head so I can take it in & have it all gone though. then just pop one off & though on the other. Still whighting for the racer Walch cat. thanks agine
In the link below, click on the "Back 2 Basics Sheet" link at the top for a nice listing of the different Lima 2.3 heads available.  If you want to keep the orginal carb intake, the oval port heads (74-80) would be easiest.  The D port heads (81-~89) can be used but may need some epoxy on the floor of the intake to match the ports and prevent fuel puddling at the intake to head interface.  I believe some of the accessory mounting holes on these two head types may vary slightly but can be fixed.  If your head is in good shape (no cracks), it might be easiest to just replace the one bad valve.  Nice looking wagon
http://racerwalsh.zoovy.com/category/techinicalinformation/
RapidRichy
After 20  years of good service my little pinto-bean S.W. has a burnt valve. Dose any Buddy know if if any of the later mode ranger pu. cyl. heads fit a 76 2.3l
