pinto parts for sale
Date: 07/25/2018 04:51 pm
free transmissions
Date: 11/28/2019 10:21 am
72' hatchback parts wanted
Date: 08/25/2019 02:57 am
Date: 02/27/2017 10:10 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
Date: 02/05/2020 11:06 am
Date: 03/06/2017 01:24 am
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
  • Online today: 2,670
  • Guests: 242
  • Total: 242
A Frame Bushings
Started by Stuwil, May 12, 2010, 07:48:50 PM
Pangra74
And the slightest bit of play in the inner/outer tie rods will get you a nice vibration, even with well balanced wheels
Joe
1974 Orange Runabout
Lost Coz
I would check all of the front suspension point's. Ball joint's, tie rod end's, rack and pinion,rack and pinion mount bushing's, A-frame bushing's, control arm bushing's, strut rod bushing's and stabilizer bushings'. Replacement part's are available in an entire kit or by the piece. Don't forget the shock's too. Any worn part's should be replaced and an alignment should be done after replacement. The kit I purchased for the 73 was reasonable and came with all of the part's mentioned above. Take your time and do it right!
"Pinto's are Cool!"
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
Stuwil
Got a new wagon----all is good 'cept for a lose front end. At fwy speeds it tends to hunt and there is a few rattles. What to look for?-help-
