Date: 12/31/2017 11:14 pm
Date: 06/18/2018 03:47 pm
Great Cruise wagon
Date: 12/17/2016 03:39 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Oddsnends
Date: 12/20/2016 10:52 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Date: 09/17/2024 12:35 pm
74 pinto
Date: 09/11/2016 06:32 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
  • Online today: 1,258
  • Guests: 1052
  • Total: 1052
Oil filler hose Yes or NO?
Started by 1980bean, March 18, 2010, 10:39:43 AM
mikerich1972
 If you want to increase the fuel economy, please find my forum titled "308,000 mile wagon!"
In that stream, you will see my info on modifying just that very PCV system you are referring to. I have run mine this way for probably 100,000 miles with no ill affects.
In this case, my vote is NO. Don't run with the hose.....
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
I would say that you technically CAN run it without the hose. See if you can find one of those oil filler caps that some of the older chevy truck motors used. They are a tall round cap but the filter material is built into the cap instead of having a hollow cap and having the hose run from the cap to the filter element in the air cleaner. Just put a rubber plug in the air cleaner to keep the appearance nice and clean! You can find those air filter rubber plugs at junk yards from nearly any 70's (some early 80's) ford cars.
1980bean
Would it hurt anything to not run the oil filler hose to the intake? The stock intake is so ulgy Im wanting to go with a different set up. Thanks
