Date: 04/13/2018 11:30 am
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 02/10/2017 09:30 am
71-71 speedo cable
Date: 07/31/2021 09:04 pm
SVO SWAP
Date: 03/15/2018 03:12 am
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
78 pinto wagon
Date: 06/04/2020 12:42 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 02/04/2018 08:26 am
  • Online today: 1,166
  • Guests: 463
  • Total: 463
71-73 2.0 compression change?
Started by bigh4th, November 03, 2004, 07:50:34 PM
pintojoe
David Vizard's book on 2.0-liter 71-74 list three pistons for the 2000cc motor.
The compression height varies between 1.588 and 1.640 a diff of .052.
Compression ratio 8.2 1.588" (40.35mm)
                         8.6 1.611" (40.91mm)
                         9.2 1.640" (41.65mm)
I believe the 1971 got the 9.2 comp piston, the 1972 got the 8.6 comp piston and the 1973-74 got the 8.2 comp piston. All were flat tops.
Pintojoe
1973 Pinto runabout, 2000cc,4spd.
The compression ( stock) on a 73 is 8.2:1
kris kincaid
Any idea of what the compression is on a '73 2.0? If its low, maybe I'll put a turbo on mine until I blow it sky high. Then I'll have to find  Turbo Coupe!  :o
ganar dinero a espuertas
bigh4th
Hmmm...  Have you seen 73 pistons that are dished?  The reason i ask is because when i pulled the head off of my 73 the pistons were flat-tops.  Kinda caught me by surprises as I figured just about everything got dished pistons in 73.  I guess theres a chance the engine was rebuild or a 71 was swapped in its place.
if it is indeed the pistons, i'll just swap the heads off the 71 cause when i pulled the head off my 73 to replace a burnt exhaust valve, i missed on on the #2 cylinder and it idles rough.  Oddly enough, it misses every 3rd revolution.
-Harry
buzzman
it was the piston 71s had flat top piston 73 is dished    mill the head .100 safely every .040 is 1 comp point i had 118 of mine   BuzzBomb
buzzman
bigh4th
Does anyone know how the compression was changed on the 2.0 from 71 to 73?  I need to replace at least the head on my 73, but i have a 71 2.0 that will be a little more work to put in.  I know the 71 had more power, but i'm not sure if the combustion chamber was changed or pistion height.  For some reason i beleive the piston height is actualy taller on the 73 as i remember them comming up to the top of the block where as the 71 doesn't quite get to the top.
Anyone have any clues?
-Harry
