Date: 11/02/2019 10:25 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 04/21/2017 02:03 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
sport steering wheeel
Date: 10/01/2020 10:58 pm
looking for parts
Date: 06/19/2020 02:32 pm
Date: 12/31/2017 11:14 pm
  • Online today: 489
  • Guests: 411
  • Total: 411
74 with a 2.0
Started by kartracer28, July 20, 2014, 10:57:53 PM
jeremysdad
I'm quite happy with my Weber 32/36 DFEV and Hotspark ignition conversion. Mine's an auto wagon, with a 2" straight pipe from the downpipe back. It won't win any races, per se...but it'll go, especially passing speeds. That being said, if I'm passing someone, it's because they're doing 55 in a 55. lol :) The only people I pass on the interstate are those doing under 65. ;)
kartracer28
Okay, What about a better carb than the stock carb. I just found a header that will fit WITHOUT having to modify the engine mount. it runs very well but it just doesn't have much get up and go. What do you guys recommend to give it some more get up and go. I have a 2.3 on a stand in my garage that I will rebuild but that will be down the road a bit. I just need some more "passing power" Any help would be great.
And the C series Offy was made for pure rpm only and not for street use. Too big. Your stock intake is by far the best part.............not like the 2.3 where stock intake is junk. The early 2.3 racers were using stock 2.0 intakes to make more power.
Stock intake is the best intake ever made for a 2.0L Ford.
IMHO? No.  Use the stock manifold & carb
kartracer28
Hello, I have a 74 pinto with the 2.0 in it. I have a chance to get an offy "C" series intake  (2 barrel) is this a good intake for this motor and if so What carb should I put on it?
