79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 08/08/2018 12:26 pm
Date: 11/11/2019 04:49 pm
Date: 09/17/2024 12:35 pm
Date: 05/19/2018 04:56 pm
Date: 04/27/2018 10:28 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
  • Online today: 1,413
  • Guests: 1439
  • Total: 1439
Door panel removal
Started by p84, July 22, 2009, 05:23:37 AM
fordstuff
yes what he said..that particle board is pretty fragile when you pry on it..... roy
Quote from: Starsky and Hutch on August 01, 2009, 04:19:40 PM
pry on the clips only!!!!!!! not the press board!!!!!!
harbor freight sell them as well  about $7 for a set
p84
Thanks for all the help eveyone. Its good to know you can still at least get information for free !!!  I was going to try  a saws all blade to try to get up behind the panel and cut the clips. I think I'll try the sears tool !!
                                  :fastcar:
Sears sells a special "door upholstery tool" for about $10 that is 'forked' so you can get under the clips. I use the flatblade myself(Thanks, Becky!), but at the upholstery shop, I was required to use the right tool. Be careful and patient, and it should work out fine. once you get one clip out, you can gently hold the panel outward to find the next clip.
Chuck :afro:
Yes. Take off the door release handle, window handle and armrest then gently pry the panel off with a flat screwdriver. I've used a tire iron with the hubcap remover end because it has a flat but wider tip that helps pull the panel and clips out of the door. Don't hurry- the particle board in the panel is fragile. I hope this helps.  ;D
p84
Does anyone know a good way to take off door panels without wrecking or bending them?
 p84                :fastcar:
