2.3 front sump oil pan
Date: 07/24/2018 03:17 pm
Date: 03/14/2020 01:52 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 11/04/2018 02:34 am
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 03/23/2018 09:23 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
Date: 01/23/2017 07:41 am
  • Online today: 481
  • Guests: 320
  • Total: 320
Valve lash lock nut gap help!!
Started by delizious, May 10, 2009, 05:09:28 PM
I'm guessing you are working on a 2 liter. It takes a bit of practice, indeed when you tighten the lock nut it can cause the lash to tighten up somewhat. When that happens, loosen the lock nut again and turn the lash adjuster down about a quarter of a turn and tighten the lock nut again. Repeat this process until you get the proper lash.
delizious
Jello there poppets! I'm sure you remember me posting something about gas coming out of the carberator of my 1973 ford pinto wagon, well it turns out that when took a compression test it wasn't getting any pressure...so I took off the rocker arms and I was able to get a reading of 50lbs of pressure. Now I'm having a difficult time putting the rocker arms back on because I had put them on wrong the first time. I have a feeler gauge but everytime my friend and I go to do it together and I put the feeler gauge in and out and they turn the lock nuts the spacing between the valuve and rocker arm gets tighter. We were thinking about just gluing the damn thing together..haha. Any propostions?!
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
