Interior Parts
Date: 08/07/2017 03:59 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
80 pinto original
Date: 08/04/2019 10:45 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 11/08/2020 02:10 pm
Date: 04/30/2023 04:31 pm
Date: 04/24/2018 11:45 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
  • Online today: 139
  • Guests: 131
  • Total: 131
what type of head is on my pinto????
Started by flyboy1, August 06, 2009, 12:56:37 PM
Quote from: flyboy1 on August 06, 2009, 12:56:37 PM
will a roller cam out of a new ford ranger work in the d-shaped ported head????
Yes. And good info on the heads Pinturbo75.
that should be an oval port head with a d-shaped combustion chamber. although if you used a later d-port n/a head with the heart shaped combustion chamber it would slightly up  the compression and give you a little more bottom end torque. the later heads were drilled for both bolt patterns on the intake side of the headand the early ones werent. the difference in the pattern is on intake port 1, the top left intake mount point on the head will have 2 drilled and tapped holes on the later head. your origonal head should only have one drilled and tapped hole there.
flyboy1
i have a 1980 ford pinto runabout with the stock 2.3l. and im buying a new head for it. i called advanced auto parts and they had a lot of different heads...which one do i need to get?
