Date: 03/25/2019 09:02 pm
Date: 02/08/2018 02:26 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Date: 03/18/2020 01:30 am
postal pinto
Date: 06/03/2020 09:31 am
Wheel cap
Date: 04/25/2022 11:21 pm
77 pinto
Date: 08/22/2017 06:31 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
  • Online today: 1,972
  • Guests: 1012
  • Total: 1012
Do any of you have this tag on your Pinto ???
Started by Starsky and Hutch, August 10, 2008, 10:32:44 AM
oldcarpierre
Someone likely has answered this already, but just in case.  The St-Thomas plant, near London Ontario, is still around.  They build the Crown Victoria, the Grand Marquis, the big Lincoln (I forget what they call it), as well as the Police Interceptor and the taxicab version.
Even before the sky fell in the fall of 2008, the St-Thomas plant's future was in doubt, as they had no replacement model when these large rear-drive cars were at the end of their run.
I regularly drive on highway 401 betwen London and Windsor, and I used to see multiple ca haulers with these cars on them.  They unfortunately have become a rarity.
Bill 77 turbopinto says he`s had a few america built pinto`s with this tag so they must have applyed it there too....
No, I have a 1976 wagon with this tag. I have also seen a 1970 Maverick with the tag. The St. Thomas plant (was)? in operation building these for many years.
 maybe just the 70 models where built in canada in the begining
Reed
i read that all the very first pinto`s came from the (canada plant) then later not sure when,,, they started in the u.s.a plants... ie:one in California....
Thankyou very much Bill and Chris for your time and knowledge....
That is a surprise! I had read that no other cars were equipped with them but Canadian models.
I have had a few non-Canadian Pintos with that tag. Sometimes it is located on the upper right of the radiator support like in the photo, sometimes it is on the lower part below the radiator on the right side.
Wow - this is one I can help with. This tag is called a "BUCK" tag, which was applied only to those Pintos that were Canadian built (in the case, at the St. Thomas Ontario plant). This tag contains information about the car (obviously in code numbers) that tell you something about options, color, trim, body style, VIN, etc. It IS in addition to the VIN plate and the sticker found on the door jam. Check all of them and see what you find in common. Some codes are indecipherable; Mavericks also had them, and the guys on the Maverick group have just as little information about all the codes as we do.
What is neat about the buck tag is that it distinguishes your car as Canadian built. Mine was as well. Hope that helped.
On the front left side by the Rad ,,,and whats up!!! with the punched out   F      (I figured out what a few mean)
