74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 01/30/2017 01:48 pm
Date: 11/08/2020 02:10 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 10/05/2017 02:26 pm
Date: 09/17/2024 12:35 pm
  • Online today: 584
  • Guests: 395
  • Total: 395
No headlights??
Started by DreamBean, June 30, 2012, 09:48:38 AM
DreamBean
I have a spare foot brake switch and headlight switch (Thank god for donor cars) I will swap them out tomorrow and see what happens, Thanks ohsix9 & tigger.
Go Ford, Go Fast Or Go Home!
It is probably the headlight switch.  There is a circuit breaker of some sort built into them.  As they get older, they start kicking in the breaker as they get hot.  I have had this problem a couple times now.  You got any spares you can try?
OhSix9
corroded or dying foot switch is a likely culprit.
Virgil to Sid
DreamBean
 ???  On the way to work friday mourning the headlights just went off. So I pulled into a parking lot to see what I could find and they came back on So I went on to work. This mourning, The wife drives it to work and they go out again. Were do I start? Electrical problems are my worst nightmare. I am thinking ground or fuse. The schematics I have for an 80 zoop. I will check the rest of the lights when she gets home from work.
