Date: 06/05/2018 09:13 pm
Date: 08/30/2018 12:59 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
V8 rear end
Date: 04/12/2018 10:57 am
pinto wagon parts
Date: 12/19/2019 01:43 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Date: 04/14/2023 06:15 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 1,972
  • Guests: 1335
  • Total: 1335
Turbo 2.3's, Gears & Tires sizes
Started by Wittsend, November 30, 2008, 12:29:08 AM
If you know the hight of any tire and rear end ratio, you can calculate with the link below but here are your numbers anyway based on a 205X50X15 tire size (22.8 inches high)@ 6000 RPM with 3.00 gears. I calculated high end to show you that I would go with 3.40s to use all of the gears. Otherwise you have a 3 speed with overdrive and one you don't touch. IMHO
I'm guessing at some of your T-5 gearing but thats why I put two 5th gears :fastcar:
T-5 Trans...
1ST 3.97.......34 MPH
2ND.2.34......58 MPH
3RD 1.46......93 MPH
4TH 1.00......136 MPH
5TH .85........160 MPH
or
5TH .79........172MPH
http://www.coastdriveline.com/htmlfolder/calculator2.html
Well..., now that I have the Turbo Pinto "running" (sort of) I need to contemplate tires sizes.  For the record I have the following:
1973 Wagon
1988, Intercooled, Turbo Coupe engine (otherwise stock)
T-5 with a 3.97 / 1st - .85 / 5th
3.00, 8" rear end
15" wheels I would "like" to use (if it is not an issue)
  I'm not looking to make this a drag car. When I finally found a 8" rear end I actually had a choice of 3.00 or 3.55 gears. I opted for the 3.00.  At the time my rational was: gas was $4.69 a gallon, the T-5 has an extremely low 3.97, 1st gear and the Pinto weighed 1,000 pounds less than the T-Bird.  Thus, the 3.00 gears were compensated for by the lost 1,000 pounds.
Anyway, for the time being I'm using the T-Bird's 225-60-16" tire with the 3.00 rear.  While I wouldn't call it a horrendous bog, it doesn't move out quite like the 1,000 pound heavier T-Bird did.  But then, the T-Bird had 3.55 gears, - now didn't it.
So what I'm hoping to find is a tire size that compliments the 3.00 rear end, but it also factors for the 1,000 pound the engine no longer has to pull around.  I would like to find the Turbo Coupe 3.55, 225-60-16" like performance, but hopefully at a somewhat lower RPM because of the weight reduction.
  To complicate the matter I bought some wheels/tires on sale.  They were 225-60-15"  Unfortunately the tires have flat spots and are useless.  But, having invested in the wheels I'd like to stick with the 15".
Here are some calculations I have come up with:
  Baseline -
Stock 1988 Turbo Coupe 3.55, .85 overdrive, 225-60-16" tires = 2,525 RPM & 65 MPH (frankly my recollection was closer to 2,200-2,300 as the tach read, but what do I know???)
  Proposed -
Turbo Pinto 3.00, .85 overdrive, 195-60-15" tires = 2,301 RPM & 65 MPH
  OR
Turbo Pinto 3.00, .85 overdrive, 205-60-15" tires = 2,264 RPM & 65 MPH
  And for what it is worth, the temporary current setup is -
Turbo Pinto 3.00, .85 overdrive, 225-60-16" tires = 2,134 RPM & 65 MPH
  Anyway, I was hoping there is a Turbo Pinto owner out there running 3.00 gears and has found the appropriate tire size.  I'm not into changing to a more "ideal tranny ratios or rearend ratios."  That cost is not to be considered.  What I am trying to do is purchase a tire size that brings back the stock Turbo Coupe performance (or better) but takes into consideration that it can be accomplish at a lower RPM because of the 1,000 pound weight reduction.  My thinking is that the 195 or 205 - 60-15" tires will do that.  If someone can speak from experience it would be greatly appreciated.
  Pardon my rambling, repeating - I'm just trying to make sure that I can be understood as what what I'm asking.
Thanks, Tom
