Date: 07/01/2019 12:23 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 10/25/2019 03:30 pm
Date: 08/03/2018 09:19 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 08/13/2017 02:01 pm
  • Online today: 1,972
  • Guests: 417
  • Total: 417
Weight Reduction
Started by LSXPINTO, October 17, 2008, 11:50:08 PM
wedge446
Get a hole saw and cut everything thats not needed
LSXPINTO
weight reduction update
back seat with sound deadening behind seat 41lbs
crash bars 9lbs each side                                18lbs
prostar xp's to greg welds                                45lbs
        =97lbs
still need to cut up the rear bumper reinforcement and remove all the unneeded stuff under the car (gas tank/exhaust hangers, undercoating) and anything else I can find
Scott
1979 Pinto LS1 76mm turbo project. th400 trans. 8.8 rear. 11inch 5 Lug on all four corners.  Hopefully it will be done spring 2009.
LSXPINTO
Scaled the car tonight for kicks with just the motor and rear and full (race) interior.  2120lbs.  so I figured around 500lbs for trans, cage, radiator, fuel cell, turbo and other bs.
Good looking car! It will be really >sick< wiith that monster motor - what a sleeper!
LSXPINTO
Quote from: nospinto72 on October 22, 2008, 08:50:28 PM
I saw your post in the racer forum that your car weighed 2900 lbs.
You may want to get an earlier car they are lighter but they have a smaller engine bay.
That isn't it's current weight that was bone stock a/c, heat, carpet sound deadening, full tank of gas with the stock tank, steel wheels,  stock bumper supports crash bars, spare tire/jack, stock radiator, vacuum brakes etc.
The LS1, TH400 and 8.8 rear are in the car.  Too much work to switch and not to mention finding one in  decent condition.
I've seen some pretty lightweight v8 79s so I'm hopeful.
SR
nospinto72
dragracing rules
LSXPINTO
Quote from: BlueGoldPinto on October 20, 2008, 08:35:00 PM
I'm sorry, I saw your subject title and I just have to post this......
Have you tried Jenny Craig?
or mabye some of those Slim Fast shakes?
;) ;) :D ;D
BGP
Thanks ;D  I'm working on that.  5lbs down 20 to go.
BlueGoldPinto
;) ;) :D ;D
BGP
you would be surprised at how heavy window glass can be.  use lexan
turbo74pinto
 if your just going to drag it and not do any nascar turning, dump that front sway bar.  if it has it.  i took the sound deadening crap from the fire wall off also.  i switched to manual brake and steering too.  also got rid of the windshield washer stuff.
turbo74pinto
Quote from: map351 on October 18, 2008, 04:57:40 PM
The 2.3 turbo will go deep in the single digits.
Flanders 2.5 goes 8.90s
JD's this would be a 9.80 > http://www.eville140.com/video/jd120.wmv
Joe Morgan went low 8.32 > http://www.youtube.com/watch?v=ufdZGwjGKP0&feature=related
wheres Huber??  79 fox body, fastest i think is 8.97 now.
bob
LSXPINTO
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
LSXPINTO
That ls1 looks sick.
I've got the ls1 in with a th400.   Actually it took my Brother some time but that's what he does for a living.  It's getting a 76mm turbo with a liquid to air intercooler.
I'm going for single digits ;D
map351
LS1!
By the time you make all the modifications to make a LS1 fit you could bolt in a 2.3 turbo and have a mid 11 sec street car. I just installed a LS1/T-56 in a 39 Chevy Cp and a LS1 Ain't gonna fit in a pinto without moving the firewall and the trans tunnel.
I used a Bitchin Big block firewall and had to add 2" to make the LS1 fit, then the trans tunnel was another nightmare because the trans is so wide. Your in for a lot of work.
Sell the LS1 and build a good 2.3 Turbo..
73 2.3Turbo Pinto
Pinto FiberGlass
LSXPINTO
Quote from: douglasskemp on October 18, 2008, 10:56:46 AM
FIBERGLASS...
Need I say more?
Oh, and if your car is the one in your avatar, post some pics!  I have always liked the cars with the Ford accent stripes...when I was a kid I wished for a black 79 Bronco with the red/orange/yellow stripes.
Pics...
FIBERGLASS...
Need I say more?
LSXPINTO
I have an aluminum LS1!
I want it as light as possible.
Scott
map351
73 2.3Turbo Pinto
Pinto FiberGlass
Smeed
'73 runabout
apintonut
go aluminum engine cuts the weight way down!
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
LSXPINTO
I'm looking for something I missed to get some weight out of my 79 Pinto.9
I've done everything I could think of.  Any other ideas?
Here is what I have so far.
Sound deadening under carpet 35lbs with carpet
HVAC 41.5lbs not including condenser.
spare tire/jack didn't weight
Front bumper supports changed to chrome moly
and a few other things
I'm also going to remove the crash bars in the door.  Any Idea what they weight? UPDATE 9lbs each.
Thanks,
Scott
Here are the things i've weighed so far
seats 32lbs each
heater controls 4lbs
8track player 6lbs
heat ac box 27lbs
vents 3lbs
carpet with sound deadening 35lbs
rubber a/c hose in fender
2 factory door speakers .75lbs each
back seat with metal bracket 39lbs
sound deadening behind back seat 2lbs
