SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
Date: 01/12/2019 10:19 am
Date: 03/13/2021 12:57 pm
Date: 08/08/2017 01:44 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
Date: 11/12/2020 08:28 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 04/12/2017 06:57 pm
Date: 02/28/2018 09:18 am
  • Online today: 506
  • Guests: 372
  • Total: 372
Window felt scrated my glass!
Started by dave1987, September 13, 2007, 12:14:40 PM
Same here. I was going to pay $20 per door to get good glass from the salvage yard!
I'm gonna have to rememer this.... I have the same problem on my 77 wagon.
thought I was going to have to replace the glass  ;D
Yes, the stuff I had was pretty abrasive however, it has been quite a few years since I had the windows out on my Mustang so I do not remember exactly.  I remember I screwed up the first batch I mixed.  The second batch worked however using the drill screwed up the glass.  At the time, I thought I had to replace the window because the swirls were so deep.  I decided to "sand" it down by hand to see if I could fix the swirls.  I was amazed how quickly I had it fixed.  It did not take long and you cannot tell.  I imagine it is a little thinner now but it has been probably over 10 years and I have not had any problems.
I'm guess that after the powder is diluted, it's pretty much a form of liquid sandpaper then?
I used the Eastwood version on the rear window of my 67 Mustang.  It worked but don't use the drill.  Because the compound was really abrasive, I ended up doing it by hand because the drill left too many swirl marks.  Using the foam piece in checker board motion did the trick for me.
Both of my door's have scratched glass due to weathered window felt strips that have cracked and dried out. The driver's side is the worst you will ever see, but the passenger's side isn't TO bad.
Has anyone here ever used this kit from JC Whitney with results?
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000163373/mediaCode-ZX/appId-5000002000756/Pr-p_CATENTRY_ID:1000001633735000002000756
I'd like to restore my glass but I don't want to end up replacing the entire thing in the end.
