Date: 11/02/2019 10:25 am
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Rear Bumper
Date: 07/26/2021 01:08 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 07/01/2019 03:17 pm
Date: 03/06/2019 06:40 pm
Date: 06/30/2018 09:48 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
  • Online today: 515
  • Guests: 293
  • Total: 293
LA3 LB3 questions?
Started by 2point3turbo, June 07, 2007, 05:05:12 PM
2point3turbo
turbowagonman
I have a Manual Brake 80 Pinto 4 spd. Pedal Assembly I'm willing to sell.
I didn't install the Boost Switch in either of my projects.
turbowagonman
2point3turbo
Thats what I was thinking but had to ask. I am going to be switching to T5 eventually but I need to get the parts from a Merkur stick to do the swap. So if anyone has these parts please email me. I have the T5 I just need clutch pedal and cable and what ever else is needed. By the way... is the Boo switch really needed?
turbowagonman
I think the LB3 is the Auto Computer and the LA3 is the Stick Computer. If that's the case the LA3 doesn't hook into the tranny. If you have a C-3 it doesn't hook into the tranny either. Right????
So if you have the LA3 it doesn't matter if you have an OLD C-3.
turbowagonman
i think the only difference is in the controls for the overdrive auto that was used in the tc. im not positive , but the difference in the factory rated power came from the T fitting on the compressor of the turbo that worked the wastegate.it had a different size opening to regulate the boost to 10 lbs. the timing curve should be the same on the 2 computers.
2point3turbo
I have a C3 auto and put in the LA3 but want to know if I should run the LB3 instead?
