Date: 09/09/2018 03:22 pm
Date: 02/14/2018 01:34 am
Date: 03/23/2018 09:23 pm
78 hatchback
Date: 03/12/2023 06:50 pm
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 07/21/2017 11:49 am
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 1,166
  • Guests: 89
  • Total: 89
Part Identification Help
Started by 1972 Wagon, February 07, 2017, 12:57:12 PM
robertwwithee
Ur right, more likely back up switch.
Ok then it has to be kicker , it's for when you turn on the A/C it speeds up the engine (or keeps it from dying) a tad , you have to use a volt meter to test it to find out , when the A/C clutch is engaged you should have voltage on one of the wires , been years since I have seen one , the newer ones used vacuum to do the same thing , hope this helps , Later   Blane in Mississippi 😇
1972 Wagon
The car is an automatic with factory installed A/C. The backup lights work. I had not driven the car for many years and finally got it back on the road. I can't remember if the connector was like that in years past. My 90 year old dad (original owner) can't remember what it was for either. I figure someone else might have a better memory!
*The Original Family Car: A 1972 Pinto Wagon*
Ordered by my folks from Bunnell Motor Company, Inc., Bunnell, Florida
Delivered: June 20, 1972
Entrusted to my care: August 1976
if she has a manual trans it could be the backup light switch , if it had more wires on it it would be an auto trans , but since it is unpluged the starter would not work , (unless it was bypassed )  way to check is to put the car in reverse and turn the key one and see if the backup lites work , if they do she might have A/C  and some had a kicker that speed up the engine when you turned on the A/C , most over the years have disepered  :o
robertwwithee
It's been awhile since I owned an automatic Pinto but I do remember a plug like that heading down to park/neutral safety switch.  Is car an auto or stick? If stick it might not be used.
1972 Wagon
Can someone identify this part? It is in a bundle of wires that run along the fire wall and end above the master cylinder. I have checked my books and can't find a picture. Thanks
