Date: 12/15/2018 02:21 am
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 07/11/2023 11:39 pm
Date: 12/10/2017 01:14 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 05/19/2018 04:56 pm
Date: 02/27/2017 10:10 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
  • Online today: 2,909
  • Guests: 2734
  • Total: 2734
1980 ESS Turbo Restomod
Started by Alpine615, May 21, 2012, 03:28:19 PM
AN ESS Pinto has to be as rare as a Group 2 Pinto I would think. I've only seen one ever. Hope it got finished and being driven.
Hey Alpine. Was searching through old posts and noticed it had been quite some time since anything was done. Were you able to get anything done to the car? Hopefully better luck than I had with my 1980 lol
Alpine615
Well I went to the junkyard today and turns out the last "mechanic" that touched this particular Mustang already unbolted the crank pulley for me! So now all I had to do was get the hub. Cordless impact wrench from Harbor Freight for the WIN! After switching between clockwise and counterclockwi se motion for a minute, the bolt began to back out.
However...I could not get that hub to come off. I tried gently prying with a flat screwdriver, I tried my slide hammer (and ended up slightly bending the thing)...so now I'm at a loss...
I read a post on AllFordMustang s that said to thread the crank bolt back in a little (without the washer) and use the jaws on the INSIDE, but I ran out of time today...hopefully it's all still there next time I can come back (probably sometime in April)...
Also, Photobucket is down at the moment...maybe I can add pics tomorrow or Monday.
1980 Runabout
Alpine615
Thanks for the heads-up, Steve! I'll report back once I get a chance to go to the yard...
Also, you've got mail.
1980 Runabout
youre gonna need the pullies and crank hub off a ranger or a stang with dis setup... the pullies off the distributor 2.3s sits in a different location...
Alpine615
Quote from: Alpine615 on November 28, 2012, 10:46:35 AM
I should be able to add pictures in the coming weeks.
I am such a friggin' liar! Haha
Well, while I've been absolutely negligent in updating this thread (and adding pictures), I have been carving out some time to do small things here and there for the project, and mostly parts-gathering. Here's a summary for the last couple of months:
- Test fit the manifold and flanges, as well as the Datsun T3. I clocked the CHRA to point down and towards the inner passenger fender. Definitely enough room there to turn 90* to face the intercooler.
- Attempted to measure how much would need to be cut out of the upper intake to clear the stock hood. Ended up talking to Steve (Pinturbo) and BoPort about it. Just gonna have Bo do the gutting/rotating, I think.
Funny story: when I took off the lower intake manifold to prep to send to Bo, I discovered the a rodent's nest! Gonna have to take the head off and break out the air compressor to clean everything out.......what a PITA!
- Lastly I've managed to get most of the parts required to do the EDIS conversion, although I still need a dual serpentine crank pulley to be able to run the Ranger passenger side alternator properly. Otherwise, it would be driver off the water pump pulley and I don't think that's desirable. Gonna try to hit the local pick-n-pull yard this weekend to rip one off a Fox body Mustang.
I find out sometime this month about a contract extension with my job, and I've been told it just needs to be processed through the system. When it goes through, I'll be picking up the "big ticket items" to keep the project moving. Once the weather warms up I expect there to be some serious progress. Whether I'll actually post pictures up, we'll see...  :D
1980 Runabout
Alpine615
Wow! I can't believe I've been away from this thread since AUGUST! Time flies, but I don't know if the past 3 months have been all that fun..
Anyway, a quick update on my project. The car's been sitting in my friend's garage for the past 3 months, stayed safe during Superstorm Sandy, and is patiently waiting to be worked on. I recently ordered a set of "flip flanges" from a guy on the Turbo Ranger Forums (AJ Fritz) that will allow me to rotate the exhaust manifold 180*. (Hat tip to Pinturbo for posting this info on another thread!) I had done some rough fitment measurements, and I think this will work. My reasoning for going this route was I was hoping to avoid cutting the inner passenger fender where the battery normally rests to make room for a turbo in the "stock" location. Also, I should be able to keep my heater.
I also picked up a used T3 that began its life on a 1982 Datsun 280ZX, and will be looking to rebuild it over the holidays. I plan on measuring the space for a FMIC, and fabricate mounting brackets as well. I've read that a 25" x 12" x 3" would fit nicely. (eBay link: http://www.ebay.com/itm/160654709024?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649) Once that's installed, and the manifold and turbo are mounted, I can start to figure out how I want to route the piping. I still need to figure out the upper intake (from the '88 TC) and how much to rotate it for the FMIC. There's another eBay auction I have saved for this work, since I can't do it myself. (http://www.ebay.com/itm/150745265601?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649)
-Steve
1980 Runabout
Good deal! I got a LOT of work to do to my alloys to make them look good but it will be worth it in the end.  Just sticking with the 13s on the car.
Alpine615
Quote from: r4pinto on August 28, 2012, 11:27:45 AM
That's looking really nice! What size are those wheels? They look sharp on there. Then again they are similar to the design of the alloys  ;D
Thanks, Matt! They are 15" rims...rear discs are 11" or 11.25" (same as front) and they BARELY clear the small GM caliper...
And the fact that they look like the optional 13" alloys from Ford was the major reason I bought them. They will look even better when I can have some small screw holes drilled in them so I can install my Granada 5-lug center caps and get rid of the cheap, plastic ones that came with it!
1980 Runabout
Alpine615
More pics...
On the ground for the first time in 9-1/2 years!!!
Pushed it outside to give it some fresh air...
The next morning...
Now it sits in its new home: my friend's garage...but for how long??  :o
Celebration time!  8)
1980 Runabout
Alpine615
MAJOR UPDATE!
Car has steering, suspension, brakes, wheels & tires installed! Photobucket was giving me trouble at work, and then wouldn't upload on my cell phone and I wanted to wait to post until I could show pictures! Feast yer eyes...
Front passenger side...11" Granada rotor with small GM caliper
Rear driver side parking brake cable (temporary fix, hahaha  ;D )
Test-fitting the 15" Ansen Sprint rims
Tires mounted
1980 Runabout
Alpine615
Last week was huge. My friend came over and we installed the engine & transmission (even if only temporary), and then proceeded to install the coil springs!! Even with the weight of (most of) the engine, he still had to stand on the car to weigh it down further. I managed to jack up the lower control arm on the ball joint (with the grease fitting removed, of course) and thread the castle nut on the upper ball joint, connecting the spindle to both arms. FINALLY!
Then, this past Monday I put in the shocks and strut rods (not a great picture, I'll admit)...and as a bonus I put the driver's seat back in...
Later this week: front brakes, sway bar + linkages, modify the Pinto spring plates for the 2-3/4" U-bolts (for 8" rear end), bolt up the rear and do the rear brakes...phew!
1980 Runabout
That sucks that it wouldn't go together easily. Too bad you don't have a couple buddies who can come over & sit on the core support to add some weight.
Alpine615
Quote from: Pinto5.0 on July 25, 2012, 03:45:24 PM
Just do what I'm doing & make it your own. My '80 has some interesting options of it's own so I'm keeping the stock interior & exterior treatments down to the side stripes. I like the Rallye spoilers so I'm adding them on but I'm modifying the rear to work with my steel hatch. I also have one of Map's ducktail spoilers that may get used if I like the look better with the rear window louvers.
'77 tail lights & bumpers are going on & I have a steel 2" cowl induction scoop that I'm going to weld on to the hood to clear the eventual turbo addition & I may add a filler door over the gas cap since I have pinholes around my gas cap & need to fix it anyhow. That's it, just some changes to set it apart & personalize it to my tastes.
Do the blackouts around the side windows & paint the Rallye stripes at the bottom without the word "RALLYE" & same for the spoiler on the back. Make it stand apart from a real one with minor changes.
Yeah, I think more than anything I like the blackout treatments, which shouldn't be hard to replicate (especially since I have great reference photos from mrskydog's Rallye.) And I have always liked the Rallye package, but also I was thinking it would be a crime to remove (a.k.a. destroy) the Rallye tape stripe on the spolier and re-paint it to match.
It is obviously a decision that will have to be made a little further down the road, and I have other things to focus on. We've already had to call off the realtor walk-through because the car can't be rolled out of the garage, but we still may make the desired listing date of 15-Aug. Wish me luck! :)
By the way, what you have already and what you plan to do sound awesome! I have to find it again, but I read your posts about the car a while back and I really dig the interior. Black and gold!
1980 Runabout
Alpine615
Long time, no updates...sorry 'bout that! I tried doing what Pinto5.0 suggested with my front coils, but the car still began to lift off the jackstands!  :-\  So I backed it down and will try again once the engine and trans are in. I don't know why it didn't work for me, but I will upload a pic later tonight.
On the to-do list this afternoon:
- Install the steering rack, hook it up to the steering joint
- Lower in the engine/trans and bolt up
- Install the driver's seat and steering wheel
Next week:
- Front suspension???  :)
1980 Runabout
blink77
Steve-- Glad everybody is happy. That must be
your girlfriends cat (now your best friend). Nice
looking cat. But you know we love cats. I wish I
had gone with you to Kirk's. But, he is close enough
that I'll see that great car somewhere along the way.
I was happy to meet you and I think the right guy got
the parts. Sally says Hi!! Good luck with the house and
finding a place for your Pinto and your stash of parts.
You are one dedicated guy!!! Keep in touch.
Quote from: Alpine615 on July 25, 2012, 11:57:58 AM
Yeah I've wanted the all-glass look for a very long time. And it wasn't until recently that I found ESS emblems on eBay. But now that I have the Rallye spoiler, I am not sure what I want to do. I think getting the side lettering and stripes reproduced will be extremely expensive, if anyone can/will even do it. I've contacted Phoenix Graphix, but haven't heard back yet.
Anyway, the exterior is the last thing I should be worried about. Three weeks until the parents' house is listed. Ahhh!
Alpine615
1980 Runabout
going all glass hatch I see. I dunno if I would wanna do that with mine. I like the rallye look but not sure about the all glass back
mrskydog
Steve what a great find on the spoilers  Very Nice!  it was worth the trip. Hope to meet up once the car is complete again.....Kirk
;D
"Living the Dream...Driving Old Fords"
1965 Mustang 2+2 Fastback
1980 Pinto Rallye 32,000 Org.
1972 Maverick Grabber V-8 car
2005 Mustang
Alpine615
While I was snapping pics of my coil spring insulators last night, I decided to I would clean up and take pictures of my recent "haul" out to Michigan. I met up with Bill (blink77) and his wife, Sally, to pick up some parts from him. Why wouldn't I have him ship them, instead? Because one of them was this:
Bill said he didn't want to ship the all-glass hatch, and I don't blame him! Years ago I bought one from Oregon and it broke during shipment. Luckily it was insured, and I got my money back, but these suckers are tough to locate. And when you do, they are usually half a world away! I also purchased front and rear Rallye spoilers, deluxe door panels, wood grain A/T shifter & bezel and a Mustang II center console. In between grabbing parts for me, Bill was showing me all of their rides, all wagons: a red '79 with vented hood, a '77 pro-stock with '79/'80 fenders, and a '76 with a Mustang V8 in it. I couldn't be happier with my purchases, and it was a pleasure to spend part of my afternoon with Bill and Sally, who were very welcoming...
After I loaded up my purchases, I took a 45 minute detour further north into Michigan to meet mrskydog (Kirk) to see his 1980 Rallye first-hand. All I can say is, wow! What a beautiful car! I posted a separate album, see this link: [size=78%]http://photobucket.com/80rallye[/size]
It was a looong journey, but well worth it. Thank you to Bill, Sally and Kirk!
1980 Runabout
Alpine615
Good deal, I just used Buy It Now on a pair of them for $20...they should arrive Monday.
My old isolators are still pliable, but are showing signs of cracking. I'm sure they would still be fine, but as I mentioned in a previous post, practically everything else that is going in this car has been replaced. Once you start, it's hard to stop...
1980 Runabout
During my 1st attempt at installing the coils I had the jack where you tried but it lifted the car so I went to the end under the ball joint for more leverage.
I wire wheeled my stock springs & drowned them in chassis black. I also re-used my isolators since they were still pliable & showed no sign of deterioration.
I picked up isolators off Ebay for 20 bucks. They were an exact match for the stockers. Here's the link. I don't think Dorman makes them.
http://www.ebay.com/itm/NEW-MUSTANG-II-COIL-SPRING-CUSHIONS-PADS-GASKETS-1-PAIR-/300745526979?pt=Motors_Car_Truck_Parts_Accessories&hash=item4605d48ec3
Alpine615
During my failed attempt at compressing the spring, I was concerned about damaging the grease fitting, so I placed the floor jack on the front lip of the lower arm...a little too dicey for my liking, as I was lined up directly with the spring (as opposed to your picture, where you go in from the side.) One small slip and that spring could've expanded with explosive force. I like your method because it gives more support to the arm, but I agree I'll need to remove or protect the fitting.
10-4 on lining up the bottom of the coil with the notch in the lower arm. I think I want to replace both rubber spring pads (coil spring insulator, as RockAuto lists it) but the picture looks different from what I removed from my car (I'll upload a pic when I get home tonight). Can you, or anyone else, provide a replacement part # (like Dorman/Help!)?
And yes, I am re-using the stock springs, which have been coated with Eastwood rubberized rust encapsulator.
1980 Runabout
Quote from: Alpine615 on July 24, 2012, 10:14:52 AM
Pinto5.0 - That's brilliant, thank you for the advice and photos. Will give that a try this weekend, hopefully sooner.
I hope it works for you. Mine snapped together like Lego pieces on the 1st try. Make sure you either leave the grease fitting out or use a THICK towel under the ball joint so you don't snap the Zerk off.
I'm assuming you are running 4-cyl. springs. I don't think V-8 springs go in without banding them.
When you jack it up to the point where the front is about to lift off the jackstands you should be able to pull the upper control arm down enough to start the nut on the ball joint.  Just be sure you have the bottom coil lined up with the notch, otherwise that side of the car will sit a little high & there is no way to spin the spring to correct it unless you disassemble it again.
Also check the rubber spring pads at the top before you install the springs. Replace them if they are shot so it doesn't squeak. If one is bad change them both or you will have a slight height difference as well.
Alpine615
1980 Runabout
I installed my front suspension with my engine/trans. removed. I put my jack under the ball joint & it went together easily. Make sure the spring is fully seated at the top & clocked properly so the end of the coil will seat in the notch on the control arm.
Get it to this point with the jack in place then.....
Simply jack it up until the upper ball joint goes into the spindle & spin the nut on.
Alpine615
Sooo had a slight setback on Friday night. First, I found out that the stabilizer bar tends to get in the way when installing the rest of the front suspension, so I removed that. No big deal. Well, then I tried to use a jack to raise the lower control arm & compress the coil spring, and the whole car began to lift off of the jackstands!! Looks like I will need to put the engine and transmission in first to help give the car some front end weight.
New order of operations is this: install steering rack & steering column, engine and transmission, THEN front suspension.
I feel kinda stupid posting this, but as I said from the beginning, I am learning as I go along and this will be a catalog of all my successes AND failures... :P
1980 Runabout
