Date: 02/28/2018 09:18 am
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 09/05/2018 06:30 pm
Date: 12/04/2018 07:40 pm
1979 pinto
Date: 04/19/2018 02:02 am
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
80 pinto original
Date: 08/04/2019 10:45 am
  • Total Topics: 16,268
  • Online today: 673
  • Guests: 253
  • Total: 253
Timing Belt Cover Removal
Started by John Turner, February 09, 2013, 08:29:41 PM
John Turner
GOT IT!  Rotating it clockwise is the trick.  Thank you folks for helping me out.  jt :D
3 small bolts and lift up to the left (counterclockwise) and out.  it you do take it out try to get your hands on some new rubber grommets that the shoulder bolts go thru.
no pulleys or hoses or belts to remove it like Pintoman1 has said.
PintoMan1
done this many times without removing anything to get it off! i also have a '72 2000 in my '73.
1973 pinto runabout
John Turner
FYI, on the 2000cc, 1972 engine, you need to remove the main drive pulley from the crank, radiator hose, etc. in order to get the cover off the timing belt.  Its a huge pain.  I have abandoned the idea of removing it to paint it. jt
Sounds like it's the same or similar as the procedure to remove the cover on the 2.3
PintoMan1
no need to remove the pulley. it should come off easy. just 3-4 bolts. and it should just slide up and out. turn counter clock wise when lifting up and out.
1973 pinto runabout
John Turner
I have a 72, 2000cc, 2V, automatic.   I want to repaint the timing belt cover, valve cover, air cleaner etc.  My question is, how to remove the timing belt cover.  It seems as if I need to remove the pulley that is attached directly to the crankshaft.  I am hoping that I am wrong.  Can someone tell me if there are other parts that have to be removed before the timing belt cover can be removed or can I just take it straight off.  Thanks.  jt
