Date: 06/19/2018 03:58 pm
Date: 08/02/2019 04:18 pm
Date: 02/25/2017 08:45 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 01/19/2021 03:56 pm
Date: 08/30/2021 03:20 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
  • Online today: 600
  • Guests: 536
  • Total: 536
Fender removal
Started by wbacon8780, February 06, 2013, 04:26:33 AM
wbacon8780
You should be able to get it off in under 10 minutes. It really is easy on Pintos.
wbacon8780
Great...that's what I want to hear...easy...thank you.
sedandelivery
I had my fender off my '80 last year to change the door hinge. You have to take the headlight cover off. There are the bolts under the hood on top of the fender, one bolt under the fender behind the wheel going straight up, open the door and one bolt on the top of the fender behind the hinge, and two bolts behind the headlight bezel, and the sheet metal screws above the wheel holding the outer fender to the inner fender. Very easy to do.
wbacon8780
1979 Pinto- I want to remove fenders to see how the metal is underneath and clean up cowl area. How difficult or easy is it? Any help would be great.
