1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 06/07/2021 08:14 pm
1974 Ford Pinto
Date: 10/16/2017 10:45 am
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
free transmissions
Date: 11/28/2019 10:21 am
pintos for sale
Date: 12/11/2018 04:29 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 01/20/2018 07:51 pm
  • Online today: 330
  • Guests: 266
  • Total: 266
fuel milage
Started by fairmont, July 28, 2004, 07:41:43 PM
straw boss
I really don't know what my intake came off of.  I found it in a junkyard in the back of a Chevy truck about 12 years ago.  My guess is it came off a Ranger, since part of the EGR valve was higher than the throttle body.  I don't think it would fit under a Mustang or Thunderbird hood.  I removed the valve and mounting boss and welded up the hole in the manifold.
In addition to that, I cut about 1/2 inch out of the upper intake, so the throttle body sits closer to the valve cover.  My hood clearance is still near zero.  I have a small outward dent in the hood from the intake to prove it.  New motor mounts seem to have kept the intake from contacting the hood since then.
If I were to do it again, I would look for an intake and valve cover from a '87-'88 Thunderbird turbo coupe.  The intake is lower, and the valve cover has a recessed area for throttle body clearance.
I did not use the stock Ford wiring or electronics, but that would be a good way to go.  I used an aftermarket ECU from Electromotive.
Handy
Hi Strawboss,
I'm a newbie here but have enjoyed reading the posts.  I have this week off so I'm looking a little closer.
I've been considering an upgrade to EFI this winter as a project for my '76 runabout.  Any advice would be appreciated.  Did you pull your EFI off a Ranger or other?   I'm also wondering what electronics need to be salavaged at the same time.
1980 Bobcat
1976 Pinto
straw boss
Once I managed to put something like 13.2 gallons in my Pinto.  I was driving on fumes.  Now that the car has fuel injection, I don't let the tank get much lower than 1/8 tank or it will $uck air on a left hand corner.  If I drive conservatively and stay at the local 55mph limit, I can get 33-34 mpg in the summer on my 18 mile commute.
My '74 runabout has a 12.5 gal tank & gets around 25MPG (mine's a 2.3L auto)
Brando
My 78 wagon has a 13?14? gallon tank and got rougly 17mpg.
fairmont
hi pinto fans
i am new to the site and i have had alot of pintos in the past i am currently looking at a 74 pinto wagon can any one tell me what kind of milage thay get and how much gas thay hold
thank you
todd <fairmont> :)
