cam pulley
Date: 05/30/2018 04:56 pm
Date: 12/13/2016 10:25 am
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Date: 11/08/2020 02:10 pm
Date: 10/11/2019 11:13 am
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 02/18/2017 05:52 pm
Date: 11/05/2016 09:03 pm
  • Online today: 531
  • Guests: 421
  • Total: 421
Looking for help...pinto racer
Started by cmcpinto21, November 13, 2008, 08:30:06 PM
first rear:
WGF AN9AB 08 67 206B
I believe should be more like:
  WGF  AN 9AB
3.08   67   2068
Which would code out to a 6.75" rear with 3.08 gearing, no trac-loc
for the other, I cannot find the 'RF' prefix code anywhere in Ford codes.  You may be able to find it here:
http://www.hotrodders.com/forum/ford-rearend-axle-tag-id-codes-posted-130274.html
OR, is there the possibility it may not be a Ford rearend?
Good luck! :D
first trans; no idea, second; 1977, third; 1975. The 71,72&73's had lower 1st and 2nd. (you are running in 2nd gear, right?)
can't help with the rears, there should be gear ratio numbers near the end of the tag where it is bolted on, if they are 6-3/4, 3.08, 3.40 or 3.55
cmcpinto21
I race a 74 pinto mini stock in Atlanta GA in the newnan GA area .I am looking for someone to help me at the track and the shop i really need a great motor guy ....
I run a 2.0 with a 2.14 trans and a 3.55 gear on a 3/8 of mile track very high banking....any way i also have a trans and two rearends that i cant identify
   first TRANS # ford 80240    77ET7006AA    75ET7A039AB
   first REAREND#   WGF AN9AB 08 67 206B
   second REAREND# RF D12W 4026B
      any help i thank you
