parting out 1975 & 80 pintos
Date: 10/31/2018 12:00 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Two 1978 Pinto Station Wagons
Date: 05/18/2025 03:10 pm
Date: 09/19/2019 04:43 pm
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
Oil pan front sump style
Date: 01/10/2017 09:19 am
Date: 02/22/2017 01:58 pm
Squire trim
Date: 03/28/2018 10:11 am
Date: 08/09/2018 07:49 am
  • Guests: 2357
  • Total: 2357
New project... 1980 Runabout
Ok gotcha. Hopefully after I replace those two gaskets (EGR and carb to intake) the car will run better.
It might be an issue if the lack of its presence allows a air leak beneath the Choke plates... as an example:  a bypass when the chokes need to restrict the air to the venturis in the carb throats
That's it. Couldn't recall the name. Is it possible that not being there is causing an issue?
It appears to be the switching bowl vent. This vents the fuel bowl fumes to the Canister with the engine off, and when your start the car the fumes are routed to the Air cleaner. Another way to stop fuel vapor from evaporating to the outside air in emissions speak.
Well that solenoid did come on the car but not currently there. The one I am talking to is a solenoid on the top front of the carburetor held on with three screws in the area of the fuel filter. The 1980 carburetor had it, the frankencarb on the car did not. I say frankencarb because the top plate is from the 77 and the body from a 76. The 77 ran good with the carb. The top that was on the 76 carb had a leaky plug on the end so I swapped tops.
Does the car have wiring for the Solenoid ? A single wire connector spade? You may have the dreaded Idle solenoid plunger application. It's supposed to open the Butterflies ever so slightly when the key is turned on to start the car and hold the curb idle while the plunger is extended. This whole deal was to allow the butterflies to close completely when the key was turned off, thereby stopping the potential for Run on (Dieseling) .
At least the overfill is sometimes I don't do. I learned that with my 2015 Sonic that I owned  lol. The original gas cap was on the car and was of a similar style to the new one I got. Before I put the new cap it would take much more to start the car so I know the cap had something to do with that. I am going to pull the carburetor off the car today and also try to connect some of the vacuum lines, including some that I think were the charcoal cannister using pics of one I saw at the Pinto vs Maverick car show. I needed a diagram and that car gave it to me. Now, there is a funky solenoid on top of the old carburetor that I cannot connect since it is not present on the current one. Could that have something to do with it?
Both of my Late model references show the 1980 using a Pressure/Vacuum gas cap. Not a sealed non vented unit. It appears the tank will stabilize the container with the cap. The fresh air for the canister is drawn in through the canister top. The fuel separator and expansion valve is in the top of the tank. The one hard line (not fuel line) for the fuel vapor is the hose at the canister to the frame. The other "duct " goes to the air cleaner housing from the canister. BTW, if the canister is OLD, rebuilding it may be possible if you can separate the lid from the base. Using a new Activated charcoal granule pack for fish tank water filters is the right stuff. It comes in different size chunks, so match it up at the local Pet store.
And Never overfill ( Let the pump nozzle do its job ) the tank at fill up or you'll have to do this all over again ;D
Let us know what you find out..
  Pintosopher, riding a goat trail to the ranch, stepping aside the Road Apples :o
I'll need to look into how the Pinto allows air into the tank to avoid collapsing the tank, but in the case of my CIS K jetronic GTI, the tank has to have a non vented cap in order to hold pressure to prime the electric fuel pump. Later , the Golf used a in tank pump and the External pump to send fuel to the  fuel injection distributor. This was to avoid vapor lock in the Lines and the Evap was changed to have electrically controlled  purge valves in the system to avoid the pre OBD 1 systems showing a pressure drop in the evap if the cap was left loose, or missing.
In summary, There must be a way for fresh air to enter, but not leave the tank ( Except as fumes) so the canister system can do it's job. If it isn't hooked up correctly, you have potential for an air leak while running if the Purge valve hangs up. The mixture settings of the Carb are recalibrated to allow for the intake of addition fuel vapor from the canister. To unhook or incorrectly connect the lines is the way to frustration or Operation that is Pre Smog  control in nature.
It's just me venting Again ;D
Pintosopher , a Burp and emitted gas fume from enlightenment
So the new cap now retains pressure on the system which is causing a possible evap system issue? Possibly because it is not hooked up like a 1980 but a 1977 that didn't have similar emissions?
Matt,
I'll throw another variable in the mix. If you received a benefit from the new cap, There's a evap issue in the mix. The retention of tank vapor to allow the Charcoal canister to work properly is dependent on many factors. Any ethanol mixed fuel compounds the canister purge function as the Phase separation will soak the matrix in the canister if the fuel is allowed to sit for any length of time beyond a week. If your canister has experienced "breakout" then the fumes will be obvious near the front of the vehicle. The Purge valve is a connection to the Intake from the canister and it can fail to function, creating many start and drivability issues. ( My 84 VW GTI  with non electronic CIS injection drives me nuts on this with Cal RFG fuels, and the canisters have to be rebuilt to keep the vapors to a minimum).
Also another influencing factor could be Leaks at the Crankcase venting to PCV or even the Oil filler cap. It all must be vapor tight to limit influence on the Mixture when hot or cold starts are an issue.
These are the ones that give you gray hair, or just hair loss like me :P
Pintosopher,  A horse with no Shame ;)
I put on a new gas cap and the car somewhat starts better. Not completely, but a little bit. I am going to pull the carburetor off the car to replace the EGR gasket, and carburetor to intake gasket to see if that helps. The choke works but fast idle does not. Since the car sat for so long, as did the carb I will tear the carb apart to see if there is any rust in the bowl since later in the week it had slight issues going, especially when the engine is not up to temp.
I know what you mean, Matt.  The lack of air conditioning is the main deterrent to me driving my Pinto during the summer months!
Thanks.
I got to mow the lawn, and then go to the store so I will be able to tell if the noise was a lifter that is leaking down when I start the car up. With me wanting to buy a new car in April I need to keep the miles off the Malibu to help its value some, so the Pinto is my daily driver. Good thing the temps aren't as humid, so no a/c doesn't seem as bad as it did in August.
Now THAT sounds like a day well spent!!!  Congratulations on smoothing her ou!
Just got done test driving the car. I tell you what... This engine has not run so smooth for a long, long time. At first the engine had more noise than before, but I bought the lifters and followers in June 2012 for the car's original engine. They had some slight corrosion, and the rollers weren't as smooth as I thought they should have been. After I drove the car for a while it smoothed right out. They were loud when I first started the car but quieted up after driving.
An additional benefit... No more misfire. Now the cam did have slight pitting on the lobes of the #1 cylinder but for now it'll be OK. I will worry about it eventually but not now.
Cost of repairs at this time is $0, so if I need to replace the cam at a later date then so be it.
Me too. Although right now I'm more concerned with the lifter noise. I'm missing a car show I desperately wanted to go to but wasn't sure with that top end rattle. Slight misfire and rattle tells me it was a lifter. Could hear the noise coming from the valve cover.
A gas cap can make a world of difference!  In 2004 we bought a brand new Jaguar which was to be my wife's car.  We'd had it about a month when she called me one day and said something was wrong with the car - it had gone into a "limp home" mode and was just barely driveable.  She got home with it and I placed a call to the service department of the dealership (about 100 miles from us).  The service manager suggested checking the gas cap to be sure it was not cross-threaded.  I had already checked that but checked it again anyway - all good there.  Ultimately, they had Jaguar Roadside Assistance come pick up the car on a roll-back and deliver it to the dealership for repair.  It turns out that the gas cap seal was actually defective so, although it was installed correctly, it still was not sealing well and triggered the problem.  A new gas cap fixed the issue and they delivered the car back home to me the next morning.  I hope a new gas cap works for your situation too.
Well I'd like to say no news is good news on the car, but not the case. I got the speedometer fixed, and picked up a spare cluster just in case. My Malibu has some gremlins so I am parking it to save miles, and drive the Pinto.
Rained last week rather hard and the wipers worked, although a bit jerky. May replace the blades to see if that helps. The hatch also leaks when water sits on the car so I am keeping a towel in the car. At the moment it sits in the garage with the valve cover off. The car developed a top end tick that would come and go. The engine was rebuilt with new bearings in 2008, and no metal in the oil so I am pulling the lifters and followers to see if that will fix the problem. The cam is a Ranger roller and followers which I installed in the head in 2007 before I did a bottom end rebuild. The head is a lower mileage head off a Ford Courier, so unless the cam bearings decided to fail all is good there. It was immaculate in 2007 when I installed the head on the engine. Had to replace the head due to shot cam bearings on the original head on the motor when it had 123k miles.
I have cleaned up the followers, and lifters, and are currently pre-oiling them by soaking them in clean engine oil.
As for the coolant leak a new thermostat gasket fixed the problem. The car still leaks a little oil but that will be fixed in due time with a new oil pan gasket. It leaks about a quart every 1000 or so miles. The choke  or fast doesn't work and the carburetor has been adjusted according to the factory Ford books so it's a grin and bear it situation. A new gas cap will hopefully help it start better since the old one is no longer holding pressure on the fuel system. I noticed the car starts great when warm but takes more to start when cold. The engine and carburetor started much better when in the 77. The difference? Newer gas cap on the 77.
Glad to know you're still plugging away at it!
Going to get a T-stat gasket for the car. When I installed the motor I had to replace the T-stat and housing. I glued the gasket to the housing but did not use any RTV on the head. It leaks a little when off but fine when running.
Cheap gaskets. $2 for the carb gasket and $2 for the egr gasket. When I have it off I will also inspect the valve which was NOS when installed on the engine in 2006
I know the carburetor itself sat for about four years with no intention of using but the 1980 carburetor had other ideas when it wouldn't work at all
Hmmm just a thought.... could a bad egr plate to intake gasket be the cause or bad egr to plate gasket?
Quote from: r4pinto on August 26, 2017, 09:04:47 AM
Not at all. I might look underneath and see if the stabilizer bar is causing some of the noise since the links are broken, but I might not since I got to get replacement links. The car has a full tank of gas and runs like crap when cold. The fast idle is there but barely, and it idles like crap when cold. Can't seem to find any answer on here so I won't worry about it and eventually replace the carburetor.
Matt, Check the EGR system for leaks or being frozen open. Nothing you do to the carb will help below the Carb butterflies when it's cold if too much air is getting to the intake manifold. Just a thought, My old 74 2.3L had a cracked EGR housing and nothing would help after a thorough rebuild until that was fixed.
Pintosopher, memories retained, but venting intelligence in a tech laden world ;)
Are you planning to spend the weekend working on the car?
Haven't done much to the car since coming back from the four car shows. I did pull the speedometer and sprayed some silicone spray on the speedometer assembly. Seems to have helped. I'm not completely sure it's fixed so I located a spare cluster for the car. I also got a replacement bracket that goes from the top to the bottom of the radiator core support. It's been painted and will be installed later on. I found out there were multiple bolts that held it to the car, but when I stopped at the gym outside Cleveland I heard knocking from the front end when you hit the brakes. It was the bracket hitting the bumper. It hit the bumper because only one bolt was left. I don't know where the other went but the replacement bracket came with bolts.
It was a blast. And one more Maverick to the Pintos. Good show to take the car to although it needs work to be fully reliable. It starts like crap when cold and the choke is set right. I did find an 80 Bobcat that had the vacuum line set up I needed pics of so I can get them rerouted correctly.
