Shiny is Good! => Your Project => Topic started by: pintoman2 on February 17, 2014, 08:14:56 PM
Hello, New guy here and need of your help . I'm need of a set of headers from hedman # 85601 is for the Windsor and cant remember for the 302 block I will take either or mine are not repairable If you know anyone that has these and willing to sell ,it would make my day You can e mail me @ fullerofseven@hotmail.com Thank you
Have you tried to call Hedman direct?, maybe they would set you up??..
Heddman doesn't make them anymore. A few people have looked into it.
Well, that's a bummer guess they must have gotten rid of the jig for them.
I was in touch with them & no, they will not (ever) make them again.
I have two sets. One set was on a started only engine. One NOS set.
Both will be cleaned up & ceramic coated inside & out.
Sorry, not for sale !
Best & cheapest way to replace them is have another set made, by a good builder.
I think you may still be able to buy the flat collector ?
Guess things have changed over there, there was a time they they would make just about anything.
Stainless headers mfg would be able to help you out.
http://www.stainlessheaders.com/index.aspx
You basically build your own headers out of abs plastic pipe and knuckles and send it to them. They copy it and weld up a nice set of stainless ones.. Expensive but very pretty!
Wow that is cool.. 8)
There's a set of Hooker swap headers on E-bay right now for a Pinto. Asking $556. Look under ford pinto headers. Every body I've talked to say the Hookers are much better. LOL
I understand the need for them in certain situations but flat collectors zoop, they do not vacuum from outside pipe to outside pipe very well at all. All 4 need to be in a tight grouping to vacuum each other evenly.
I don't have a set of Hookers, but if I recall, all the ones they made have the back 2 tubes go through the fire wall.
Like the old B2 headers of mine in this topic: http://www.fordpinto.com/your-pintos/new-car-!/90/
At some point I'll be building a 302w for one of my cars. Will have the Headman headers tested on the dyno & post results.
i have a hooker kit in my car i might sell dont know yet but it is a option :-\
brad :)
I got my Hookers off Ebay for under $200 shipped & they are in excellent condition. Every now & again a set pops up for cheap.
Thanks guys I've done all my homework before I got on this website and it was worth a try . Taking the wagon to a header shop next week and after that would like to hit some of these pinto shows Car was basically a strip car have taken out the steep gears and the 13.1 393w to a pump gas 306
What's been done with the 393w? Um....no particular reason I'm asking.... ;-)
I'm curious, do the Mustang II headers fit it? I found a pair of hookers for mine. They are on ebay once in awhile.
Well the 393w has a dome piston keith craft brodix heads 210 mill to get the 13.1 a custom bullet solid roller c4 with trans brake 4500 ptc stall 456 gears ran 6.40 in eighth mile on motor 5.90 on spray I would say would ran faster if motor was pushed back also 1.38 60 ft and dyno 605 at flywheel
Check out the FRPP street rod shortie headers. I think they might work for 302's. Maybe 351W's. Not cheap but well made.
What about 351W Fox swap headers on a 302? Short tubes would tuck close to the block Long tubes might hang a little low however.
MII headers don't fit the Pinto at all.
