Current Classifieds
Clutch Fork
Date: 03/31/2018 09:12 pm
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
Date: 12/24/2016 04:13 pm
Date: 12/31/2017 09:03 pm
Pinto for sale
Date: 04/19/2017 10:15 am
Date: 08/30/2021 03:20 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 09/15/2019 12:28 pm
Bell housing
Date: 08/23/2017 05:41 am
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
Date: 02/28/2018 09:37 am
Date: 03/14/2020 01:52 pm
Author Topic: 1973 PINTO SUSPENSION  (Read 2864 times)
Offline RICH73PINTOV8
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Another Pinto Driver
  • Total Badges: 3
    Badges: (View All)
    Topic Starter Signature Windows User
« on: July 24, 2014, 11:30:33 AM »
ANYONE HAVE PICTURES OF 1973 PINTO FRONT STEERING AND SUSPENSION WITH A V8 CONVERSION? ANY HELP WOULD BE APREACIATED, THANKS RICH
1973 pinto 302 ci
2013 can am renegade 1000cc
2011 victory cross roads 1700cc
2011 ski doo renegade 1200cc
Offline Pinto5.0
  • Pinto Master
  • FeedBack: +77/-0
  • Gender: Male
  • 80 hatch, 76 Wagon, 72 & 73 Sedans, 71 half hatch
  • Total Badges: 7
    Badges: (View All)
    Topic Starter Signature Poll Voter Mobile User Fifth year Anniversary Windows User 1000 Posts
Re: 1973 PINTO SUSPENSION
« Reply #1 on: July 24, 2014, 05:34:52 PM »
I have a 73 that I'm keeping the 2.0 in it. I was planning to V8 it at one time but found a 72 to use instead. I have to wonder about the rack mounts clearing the pan on 73's
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Total Badges: 3
    Badges: (View All)
« Reply #2 on: July 24, 2014, 08:13:39 PM »
the rack mount was cut out and I think a conversion kit was welded in?
1973 pinto 302 ci
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Total Badges: 3
    Badges: (View All)
« Reply #3 on: July 24, 2014, 08:34:22 PM »
I need to get a bump steer kit and install it
1973 pinto 302 ci
Offline Pinto5.0
  • Pinto Master
  • FeedBack: +77/-0
  • Gender: Male
  • Total Badges: 7
    Badges: (View All)
« Reply #4 on: July 24, 2014, 08:44:45 PM »
I zoomed in on this pic of my 73 without the rack installed. It's all I have at the moment.
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Total Badges: 3
    Badges: (View All)
« Reply #5 on: July 24, 2014, 09:13:15 PM »
thanks that looks like the same rack mount in my car,does that engine cradle rack mount bolt in? mine is square stock welded in. thank you very much
1973 pinto 302 ci
Offline Pinto5.0
  • Pinto Master
  • FeedBack: +77/-0
  • Gender: Male
  • Total Badges: 7
    Badges: (View All)
« Reply #6 on: July 25, 2014, 06:53:08 AM »
I'm not 100% sure which mount you are referencing but the engine mounts bolt at the top but are welded in. The other bolt is where the lower control arm is attached. The saddle clamp for the rack on the drivers side is massive.
Offline Reeves1
  • Pinto Master
  • FeedBack: +104/-0
  • Gender: Male
  • BAWS302
  • Total Badges: 6
    Badges: (View All)
    Tenth year Anniversary Topic Starter Signature Fifth year Anniversary Windows User 1000 Posts
« Reply #7 on: July 25, 2014, 07:40:53 PM »
What is the thread size of your tie rod ends ?
I was going to lower the rack on my 72. Couldn't find the heim joint ends that would work. Think mine is 1/2" (been a while since I measured them).
I have all the other parts.....and will not be using them - new.
Biggest reason why - the Milodon 8 qt. pan would be low enough to tap the pavement & other nasty things : ie: lowest point on the front.
My 72 has different drivers side mount for the rack.
If your rack has been lowered, without bump steer correction, it will be dangerous to drive. Or so I've read.
  • Pinto Member
  • FeedBack: +0/-0
  • Gender: Male
  • Total Badges: 3
    Badges: (View All)
« Reply #8 on: August 06, 2014, 07:54:35 PM »
found the heim joint tie rods, sleeves, and lowering tapered studs from baer brakes works fine now.
1973 pinto 302 ci
