Shiny is Good! => General Pinto Talk => Topic started by: popbumper on September 19, 2011, 09:40:54 AM
Has anyone successfully removed their rear wagon quarter windows successfully without completely destroying the seals? Are there any recommendation s for replacement material (seals) from any source that is close to the originals should they tear? Thanks.
chris
i have never pulled the rear side window but did the pop out one it was easy because the window was not in the seal and i did pull one from the hatch by taking the molding out first . on a trunk mode it was the same take the molding out first
as far as i know there is NO replacement for the seal. once you get it out there is a rubber reguvinator product out there i work at a print shop and we use the regunivator frequently i have tried it at home and it does soften up the rubber. but it eats paint as well.
Phil, I would very much like to know what the rejuvinator is so that I can find some, if you have the name handy. Thanks.
i took mine out to replace them with side panels from a crusing wagon. The front one is fairly easy because it just has 3 skrews on the one side but the other has some odd clips that i broke because i didnt need them or care for that matter. the back one is almost as easy. just took working the gasket out with skrewdrivers and pushing out on the window until you get it started then it comes right out
Chris I have good seal for $35.00 total shipped. Fred :)
Fred:
Will remove this weekend, if they split/tear, I'll be in touch, thanks!
