Shiny is Good! => General Pinto Talk => Topic started by: Wedgezilla on November 07, 2013, 05:39:14 PM
my turn signal just stopped working :-[ i replace flasher unit all my running lights hazard lights head lights still work ihave only found one fuse box...it only has like 6 fuses in it its right above my right knee if im sitting in the drivers seat is this the only fuse box??? anyone have any ideas??
Check your bulb sockets. Sometimes there is corrosion. On the front lights, sometimes the terminals do not make a good contact so when you wiggle the wires they work. The grounds in the front get corroded as well. Lastly, it can be the switch behind the steering wheel.
Every Pinto I have owned has had one of those issues which caused the turn signals not to work or work properly.
