Shiny is Good! => General Pinto Talk => Topic started by: JoeBob on October 03, 2013, 11:53:08 AM
So I took out the carpet and found wool type of soundproofing. I am putting back dynomat on all metal surfaces. Does the wool have any real value? Should I put it back over the dynomat?
I would. Your carpet will fit nicer and the wool substance will still add some sound deadening and thermal barrier qualities.
The jute holds water. I'm going with a thick heat barrier under the carpet myself.
I'm putting this down 1st
http://www.ebay.com/itm/120927753244?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 (http://www.ebay.com/itm/120927753244?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649)
Followed by this
http://www.ebay.com/itm/25-ft-floor-headliner-trunk-Heat-Sound-Insulation-Deadener-Noise-reduction-/271285771962?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f29e45eba&vxp=mtr (http://www.ebay.com/itm/25-ft-floor-headliner-trunk-Heat-Sound-Insulation-Deadener-Noise-reduction-/271285771962?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f29e45eba&vxp=mtr)
Then the carpet. I have 3 cars to do, hence the big rolls. Smaller ones are available.
Wow that looks like great stuff. I would most definitely use that over the old jute layer.
Followed by this
You can get this stuff at Home Dump or Lowes way cheaper, I just put this stuff in my shop behind the insulation.
I'll look for it. Luckily I didn't buy any yet
Well, it sure looks like the stuff I got scraps laying around I could take a close up pic of it.
http://www.lowes.com/pd_409819-56291-ST24100_0__?productId=3775471&CAWELAID=1483801671 (http://www.lowes.com/pd_409819-56291-ST24100_0__?productId=3775471&CAWELAID=1483801671)
get "peel n stick" just like dyno mat but a 3rd the cost and the roll is 36" by like a 100ft!!!
used it on my roof repair then used the rest in my wagon and my boss's 68 camaro!!
worked great and cheap so if you mess up there is plenty to recut and stick!!!\
take care
take care
Is this the stuff you get at Lowe's and building supply places??, I hear it works good as long as it's cold out but when it gets above 60* or so you get an asphalt smell in the car, I was going to try it until I heard about that??..
LIVE IN FL AND HAVENT HAD THAT SMELL YET!
AND ITS PRETTY HOT HERE!!!
Good to know, it gets up to 115 here quite often I'd hate to have that smell in a car.
The dynamat has aluminum on both faces, the building material does not.
