Shiny is Good! => General Pinto Talk => Topic started by: dedinski on July 08, 2014, 05:35:07 PM
So is rot under the battery area of the car common? So new to all this but it would be good to know =)
VERY COMMON. Somewhere around 50% that I've seen or owned.
Cool thanks for the reply. Any fixes that you know of?
depends on how bad it looks.pm pintopower he has custom battery hold downs and brackets along with some stock ones I think? hes name is alberto he is located in san jose . I will check it out when you come over to my house. chris
If still enough material left you can bolt down an aftermarket steel battery tray, I even altered mine to narrow it a bit to give header some room to not melt things.
Cool thanks AMC
Just remember, that inter fender panel is what helps hold the front end of a Pinto up.
Yipes. Probably need to patch it then hmmm
Depends on how much is compromised. Flat area easily patched, it's when you start losing bends, folds, angle and plane changes and corrugation that you really begin losing strength. Unibody strength comes from the way the material is reinforced by that, not the material itself. You can actually put holes in flat planes and not lose much doing it.
