Shiny is Good! => General Pinto Talk => Topic started by: Vicrydr on May 13, 2016, 11:09:04 AM
Well after spending all winter in Az., I finally got back to working on my wagon. I had pulled the 2.3l out of the '86 Ranger last fall and installed it in the wagon. Now I am getting the wiring in place to hook up the EFI. I cut an oblong hole in the rear of the fender well to pass the wires thru for the box as there was a hole in the panel where the battery sits. Need to mount that on side of kick panel. The wheel well panel will cover that entry up OK and there's plenty of wire to reach everything. Yesterday I ended up buying an '88 turbo coupe from a friend in town here for $150.00. Only thing missing looks like is the radiator. Body is banged up but I have lots of parts to work with now. So that brings up the idea of putting the 2.3L turbo and 5 speed into my wagon now. As the air horn from the Ranger is hitting the hood, I think I will try the turbo air horn as it looks to be lower profile. Will check out the compression and fitness of the turbo motor and think about a swap. Will get the EFI hooked up first and get this other motor running first. Lots of work to do. Later.
Remember the Turbo coupe transmission is a hydraulic clutch not a cable system like on the 4 speed for the Pinto. Also the Turbo Coupe wiring harness has a lot of things you do not need. Go to Turboford.org for more information.
Is it possible to use the hydraulic clutch system from the turbo coupe in the pinto? I'm getting a lesson on wiring from this 86 ranger EFI 4 banger. The ranger also has hydraulic clutch, but I have the old 4 speed in now. Thought about using the 5 speed from the Ranger but scrapped that idea. Thanks for the info.
Good move to forget about the Ranger 5 speed in a Pinto. The shifter would literally be in the dash. It can be done, but would take a custom shifter.
As far as using the hydraulic clutch, it should be doable. I would think others here have done it in the past. Probably not a simple bolt in though. ::)
BTW, I live in Glendale AZ.
good luck.
Russ Osborne, Thanks for the comeback. I stay in Apache Junction usually 7 months so I have to cram in work on this Pinto when I get home. I think I will use some of the parts off of the TC for now, bucket seats and other parts I can make work. I would like to install the T-5 trans in this critter also but time and a little research will tell.
I lived in an eastern Maricopa county island (Apache Trail and Crismon) for 7 years. Had an AJ mailing address which really confused people. ;D I had to prove I lived in Maricopa county not Pinal a couple of times.
You should haul the Pinto with you if you have a place that will allow you to work on it here. I know if you are in a park most of them don't like that though. Winter is the best time to work on a car here. But you know that already. ;)
