Welcome to FordPinto.com, The home of the PCCA => General Help- Ask the Experts... => Topic started by: junker on September 17, 2014, 03:01:29 AM
Hi this is the junker and I was wondering if anybody knew if a D7FZ-6223201-A regulator would fit a 1975? Thanks alot Tim.
Hopefully someone knows the details but I believe the regulators were improved in 76 but exactly how I can't say.
from what i can tell about window regulators teh 71-73 are one design 74-early 77 are another and 77-80 are another one - have used the 74-77 in early doors and worked fine! 77-80 use a square runner not a round one like the earlier years!
hope this helps - sorry dont know part numbers!
Here are the Ford numbers for 73/up.
Sorry, I don't have the earlier numbers
73/76 - before 8/2/76 --- D1FZ 6223201-B ---- Dual arm window regulator
The Ford parts book only shows one number so I assume it is the same one for both sides
77/up - From 8/2/76 ---- (RH) D7FZ 6223200-A ---- (LH) D7FZ 6223201-A
Single arm window regulator
Edit to add: I'm not able to do a numbers search so I can't tell you what you regulator fits.
Hope this helps.
